Older Catapillar 12' Road Grader
   / Older Catapillar 12' Road Grader #1
oldermfer
Northern New Mexico, Rociada
Case 530 E,Kubota L3240,Catapillar Mdl.12 Motor grader.
I purchased an older Cat Grader,it proabably is a 1950's Model.It starts with a pony starter engine.My question is, can you replace the pony starter with an electric one?
   / Older Catapillar 12' Road Grader #2
depending on the engine and year model you should be able to convert to electric start. The old caterpiller forum should be of help. I think it is acmoc.com .
   / Older Catapillar 12' Road Grader #3
you may be able to get electric starter for the pony motor but the pony exhaust heats the intake manifold on my old cat 12 8t it takes forever to tow start unless you heat the manifold
greg
   / Older Catapillar 12' Road Grader #4
greg
Seems to me it also warmed the cooling system. I'd go with the electric start conversion for the pony. Good luck.
   / Older Catapillar 12' Road Grader #6
seems we had an old dozer.. a d69u that had that setup..
soudnguy
   / Older Catapillar 12' Road Grader #7
Any pics? Old graders are sweet
   / Older Catapillar 12' Road Grader #8
The pony motor heats up the cooling system of the main engine. If you are having trouble starting the pony motor, it may need a tune up or you just need to play with the settings. Get the choke and the throttle just right and they will usually fire right off. I have run our old D6 when it was 20 degrees out and the pony motor will usually start with 2 or 3 pulls. If you can't get it started with say 10 pulls, time to walk away and try later. I grease the machine while the pony motor does it's job (warming everything up) Water gets up to 100* and the main engine fires right off and I'm off to work for 8-10 hours. :thumbsup: There were a lot of people that put electric starters on their ponies, but we have just never felt like there was a need to.
Good luck with your new grader.
   / Older Catapillar 12' Road Grader #9
How do they hand start ? with a hand crank, a ratchet rope like a lawn mower, or with a rope you wrap around the flywheel, like my fathers old Slanzi 2 cylinder diesel irrigation pump ?
   / Older Catapillar 12' Road Grader #10
You wrap a rope around the flywheel with ours.
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A52706)
UNUSED RAYTREE...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
