3 pt. hitch adjustment
   / 3 pt. hitch adjustment #1
dixie
While sitting on a level surface, with the 3pt. hitch in the full down position what should the optimum distance be from the ground to the center of the lift eyes in the lower lift arms?
Thanks
   / 3 pt. hitch adjustment #3
whistlepig nailed it...well, as long as they aren't dragging on the ground.
Why do you ask?
   / 3 pt. hitch adjustment #4
WP and Roy are correct, for most situations.
The only exception that I've found is for my post hole digger. I have to adjust the lift arms as high as possible to lift the auger off the ground.
   / 3 pt. hitch adjustment #5
I've read of similar situations (on TBN) in which a small CUT or SubCUT couldn't lift high enough for some implements...
   / 3 pt. hitch adjustment #6
Naw, I disagree with you all, Ive never had an attachment that wouldnt go down far enough,, but have had several that wont go high enough, some tractors might be different tho, but my money goes on raise um up Eric
   / 3 pt. hitch adjustment #7
   / 3 pt. hitch adjustment #8
What make and model tractor and make and model of the implement that you are trying to use? I've seen many OPs using or trying to use implements that aren't made to work properly or safely with their tractor.
   / 3 pt. hitch adjustment #9
For me it depends on what I will be using on the 3 pt. hitch. I adjust the arms so the implement clears the ground with room to spare when the tractor is moving. Not all of my equipement has their connection points at the same distance from the ground.
Ed
   / 3 pt. hitch adjustment #10
Ed
Take Ed's advice and adjust your hitch geometry as required by conditions and the particular implement you need to hitch.
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2006 FORD F750 XL 4X2 SUPER DUTY CRANE TRUCK (A51406)
2006 FORD F750 XL...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
