Got The S373D!
   / Got The S373D!
I got the exhaust adaptor all finished and welded up. Turned out good, hope the vibration does not break it though. I may add a strut from the muffler to the mounting bolts.
Here is a video of it running with the new exhaust setup:
Mitsu.mp4 video by duwem - Photobucket
Its a little loud, I will add a flapper or some sort of a tip to it to direct it forward, or mount the whole muffler horizontal for a front exit if needed, but like the "stack" look.
Everything is back apart and painted with black high temp paint.
   / Got The S373D! #12
that tractor sounds pretty good. The exhaust work looks excellent. I understand the advantage of the vertical exhaust but for me it would present some clearance issues as I was working under trees etc. Nice job.
   / Got The S373D! #13
Excellent, always good to have a new member with these skills that can help the rest of us. Glad this is working out.
   / Got The S373D! #14
Congrats. I just picked up a beaver s370d yesterday. Mine is a Satoh and has the exhaust on the passenger side....I'm going to fab a stack for mine too. Mine also has the optional front electric pto. I plan on putting a small loader on mine.
   / Got The S373D! #15
That looks like a nice unit. The front weight looks...ample! :D Also, fuel prices in your area are 50 cents a gallon cheaper than here. :mad:
   / Got The S373D! #16
If that was directed towards me, that isnt a front weight...It is a cover from the front Electric PTO. It was an option on these units and from what i'm reading on them seems to be pretty rare?!
   / Got The S373D!
Nice looking tractor!
   / Got The S373D! #18
I thought it was a weight also. Good looking machine!
   / Got The S373D! #19
could you take some detailed pics of the three point hitch? Mine has the cat 0 arms, not sure if it is "factory" though because the pto gaurd is missing bc of the cat 0 mounts. Mine seems to have the Cat 1 bar underneath the diff. I think I just need the new cat 1lift arms... I took some kubota B5000 lift arms on it (in the pic) they are not correct by anymeans. I'll need to either make a set or findsome used ones somewhere
   / Got The S373D!
Here is a picture I have saved. Let me know if you need more. I thought I saw literature some of these tractors were cat 0, but yours does not look factory.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
Utility Trailer (A52377)
Utility Trailer...
