Snow Equipment Owning/Operating Using FEL on gravel drive
   / Using FEL on gravel drive #11
My thoughts on the subject: set your bucket level indicator so it works at level and then see where it is when you tilt the bucket edge up slightly, as has already been suggested.
Let some snow and ice accumulate and pack it down to create a base on your gravel. Once the base is set then plow without allowing the bucket edge to scrape away the base. Once complete throw down sand or sand salt mix as needed in crucial areas.
Remember it's not street sweeping, it's plowing, which allows for it to not have to be a totally clean surface.
   / Using FEL on gravel drive #12
The only thing to watch about that is a refreeze...if you don't get it pretty close to bare and you get a melt during the day, you can end up with a pretty slick drive...especially on sections that don't get unobstructed sunlight...which describes the end of my driveway.
   / Using FEL on gravel drive #13
I persoanlly would stay far away from putting any salt on your non asphalt/cement road. With gravel it often softens the base and makes mud. (do a search and you will see some information on this) I personally just use a back blade that I turn around backwards and plow our 1/2 mile lane. Works great and removals very little gravel.
   / Using FEL on gravel drive #14
Hence the mention of throwing down a sand salt mix where needed. :)
   / Using FEL on gravel drive #15
I persoanlly would stay far away from putting any salt on your non asphalt/cement road. With gravel it often softens the base and makes mud. (do a search and you will see some information on this)...<snip>.
In the south, possibly, and depending on how good a base one has on their drive. Here in VT, where things really freeze, and tend to stay frozen one can choose to use sand or a sand with limited salt, (to break up the ice), mix with excellent results, IMHO.:)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2015 FORD F650 XLT SUPER DUTY 24' BOX TRUCK (A57192)
2015 FORD F650 XLT...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
