2011 or 2012 F-250 ??
   / 2011 or 2012 F-250 ?? #51
I wouldn't lose too much sleep over it. Chris does bring up an excellent point in his fondness for the F350SRW over the F250, however according to a couple of different guys over at Ford Truck Enthusiasts who build Super Duties at the Louisville Plant, the only difference between the F250 and F350 SRW diesel equipped trucks is the addition of blocks on the rear suspension for the F350. The axles and springs are identical, it's just that the blocks help prevent sag under load. If I was ordering new, I'd probably spring for the F350, but in my case I ended up with an F250 because that was what was on the lot and that's what I got a terrific deal on. I've yet to reach the limit of what my F250 can do and I've towed to the limit of what the truck is rated for. However, if I ever feel like I need the extra load capacity of the F350 SRW, I'll just buy the blocks for the rear suspension from Ford and add them myself and have an F350 SRW that's marked as an F250 ;) . I would make sure though that you have the highest GVWR package available for your truck. Chris reminded me of the fact that Ford usually has several different GVWR packages and I made sure I checked that mine was the 10,000 pound GVWR package when I bought mine. Good luck with your new truck.
These guys do not know what they are building. There is a major difference in the spring packs. Also usually different sized wheels and larger tires made to haul more weight. And as you mentioned the GVWR is the limit. DOT only cares what is on that label and that any one axle or pair of wheels is not exceeding its limit. 10,000# GVWR like you have is the highest you can get on a F-250 while the F-350 SRW can get a 11,500# GVWR.
Chris
   / 2011 or 2012 F-250 ?? #52
I guess it's a regional thing but around here you seldom see F-350 SRW pickups, many F-250's. When you see an F-350 it's usually going to be a dually.
What's amazing is how the GVWR's have changed over the years. An F-350 dually always was rated 10,000#, F-250's were about 7500# and F-350 SRW were 8800#. GM and Dodge were rated about the same.
Can not wait to see it. My gutt tells me you will have the new truck as a Christmas present. Vehicles are not moving right now so the factory should get it built asap.
Chris
Update: Spoke with the dealer earlier this week and still projecting delivery before Christmas but not sure when yet. They'll contact me when it leaves the factory so I'm still waiting to hear it's been built.
It would be nice to see it before the holidays as I have some time off and if there is some snow I can play a bit. Won't be like driving my H1 but should be fun, and more confortable too. :D
   / 2011 or 2012 F-250 ?? #54
Screw the pictures of the Ford, I want pictures of the H1! :thumbsup:
You can see it in my avatar behind and to the left of the Bobcat.
I'll dig up some photos, don't have any on this computer.
   / 2011 or 2012 F-250 ?? #56
Chris
It's been said and shown a bunch of times. The axles, wheels, tires, frame etc are all the same on the F250/350. The only thing that changes is the rear spacer block, and yes there are different spring packs for the different payload ratings. Oh yeah and the all important badge on the fender and sticker on the door jamb with the GVWR...
   / 2011 or 2012 F-250 ?? #57
The sticker on the door jamb is all the police look for around here, to determine if you are overloaded. Nothing else matters or is able to increase your capacity. On Ford Superduties, the prices are so close that lower taxes on the "commercial truck" make the F350 less expensive than the F250 so 250's are rare here in B.C.
   / 2011 or 2012 F-250 ?? #58
Funny thing about regional preferences. You're exactly right about 1 ton SRW's being rare in East Texas.
But they are plentiful in West and South Texas. Kingsville, Corpus, Victoria, San Antonio, Midland-Odessa the dealers are stocked with SRW 1 tons.
A little chevy dealer in Eden, Tx had a lot of trucks and I bet half were SRW 3500's. I don't recall seeing any duallys on his lot.
   / 2011 or 2012 F-250 ?? #59
Yea, around here the Fords and Dodges are 2/3 SRW 1 tons with a even mix of a few 3/4 tons and 1 ton Dually's. GM is maybe 1/4 SRW 1 tons and the rest are primarily 3/4 tons with a few Dually's.
Chris
   / 2011 or 2012 F-250 ?? #60
where i live, ford f35 drw from 90+ are common, gn is next most common drw, and dodge is uncommon in drw.
1 ton SRW is uncommon
3/4 ton in all flavors are very common.
Most people here, if they go 1 ton, go drw for extraaxle capacity I guess. lotsa horse farms and cattle in this area.
the people you see with 1 ton srw are usually pulling an rv.
soundguy
PALLET OF WOOD & MOLDING (A58374)
PALLET OF WOOD &...
2009 International Workstar 7500 T/A Terex Commander C5045 Digger Derrick Truck (A55973)
2009 International...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58216)
2012 TOP HAT...
