The show must go on!
   / The show must go on! #1
RDrancher
North Texas
New Holland
So what do you do when your loader joystick breaks off on the job? Improvise of course! :D
   / The show must go on! #2
hey.. a splint with a hose clamp has fixed many a thing. good job!
   / The show must go on! #4
RD, you can read my full (and very long) thread about the No Joy Joystick that started in March of 2001. I finally replaced the joystick with a new one that has a much improved design and have had no failures since. I've attached a photo below that shows we are "brothers" in southern engineering.:laughing:
"Southern engineering" is not exactly what my wife called it! :D
I followed your link Jim. Seems that New Holland learned nothing between 2001 and 2006, which is the year of my TC35D. I tightened and replaced screws forever, finally was only able to use one screw, then none. The shaft came loose a couple of years ago at the bottom. I "gently" wacked the snot out of it downward where it stuck like glue. I used a one-hose-clamp splint for the last few months after I saw a crack developing where it broke yesterday.
Fart - You'll be happy to know that duct tape is indeed in play (for the time being.) Three metal brick-tie splints, two hose clamps, a strip of rubber insulation and black duct tape to cover it up will have to do for now. I had a job today and I'm booked next week. Can't let the customers see my "Southern engineering"! ;)
   / The show must go on! #7
Good to know, RD. I just did some "body work" on my car on the places in the bumper that a bear tore out a few years ago when I stupidly left an unopened bag of bird seed in the trunk overnight. Darn duct tape gets funny after a couple years.. Bears have some sense of smell, too.
The shuttle on my little tractor loader is much different from yours, btw. I had an adventure with mine this fall when a little pin broke in the shuttle and I patched it (sans duct tape) because the replacement part was over $300.
   / The show must go on! #8
RD, the "damage" is not too bad on a whole new joystick assy including the shaft, plastic handle, and rabbit/turtle switch. Messicks.com shows it to be part number 86400438 @ $136.90.
Shoot...I have half that in "rigging" on it now! McMasters quoted me $148 and change this morning, so I have one coming in on Wednesday. It's supposed to be raining, so maybe I can get it replaced. I've been busy and repairs are stacking up! I haven't yet tackled the leaking fuel pump deal. That one has me a bit nervous!
   / The show must go on! #10
A replacement being $148, and me being a cheapskate I would have taken a different route. After extending the round rod a little and putting a ball on the end, I would be using the RT switch on the fender.:D
Then again if everyone was like me the economy would tank overnight.:laughing:
Best of luck, Bill
My hydro high / low function quit working on yesterday's job, so I finally installed the new joystick last night thinking that the plug had come undone. It hadn't. Turned out to be the fuse.
If you own one of these models with the fuse block behind the instruments and haven't changed a fuse in awhile, I highly recommend cleaning out behind the panel. The dust and brushogging junk was actually piled up high enough that the fuse block wasn't even visible! That can't be a good thing...
Oh...the new joystick sure is pretty! :D
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2005 CATERPILLAR 345CL EXCAVATOR (A60429)
2005 CATERPILLAR...
2014 Ford F-550 (A55973)
2014 Ford F-550...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
