No welder, no torch, no anvil, NO PROBLEM
   / No welder, no torch, no anvil, NO PROBLEM #1
lakngulf
Lake Martin Alabama
Kioti CK30
Well, it was a bit of a problem but I needed a two inch ball attachment for my box blade and looked for options based on the equipment and materials I had available.
So, I used
(1) an old piece of flat iron
(2) a Saws All with metal saw to cut it the right length (an amazing tool)
(3) iron and pipe on my trailer to pry the iron piece into correct shape
(4) a two inch ball unit that got bent during this episode
http://www.tractorbynet.com/forums/trailers-transportation/159210-too-much-slope.html
(5) a drill with an expensive bit
Here's what I got. Nothing fancy but it works.
   / No welder, no torch, no anvil, NO PROBLEM #2
:thumbsup:Who said that "Necessity is the Mother of Invention"? Or how about "Invention breeds success". Being a non-welder, I've been there....but still wish that I could weld. I've got so darn many tools now that are rarely used, I'm not going to start buying/learning welding.:(
   / No welder, no torch, no anvil, NO PROBLEM #3
I have welding toys etc. But to support you I would have done the same as you did. I would have choosen to bolt it on the reason being , it is easily unbolted.
I do not like grinding off welded brackets.
But if you are going to play with blades and such electric welding is needed as they do get stress cracks
Craig Clayton
   / No welder, no torch, no anvil, NO PROBLEM #4
Hey if it works I say congrats.
   / No welder, no torch, no anvil, NO PROBLEM #5
The true test of anything is wheither it works!
It does work. I did not think the metal edge on the box blade was enough to keep the hitch in place. The piece of flat iron gives it some stability and great support.
LMC LOT IDENTIFIER 131 (A53084)
LMC LOT IDENTIFIER...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2020 JOHN DEERE 7R210 LOT IDENTIFIER 48 (A53084)
2020 JOHN DEERE...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
