"glue" for rubber to steel
   / "glue" for rubber to steel #11
3M 5200 marine. That stuff is like welding, once it's dried it's never coming loose.
   / "glue" for rubber to steel #12
We have this over here, I dont know if it's available in the states, it is very strong but can be released with acitone. :)
Professional Glue
thank you all very much for your input I will do some study on the products you recommend and may be do a few tests and make a decision, thanks again,
if any one else has any recommendations, add them as this project will be a little time in coming yet,
   / "glue" for rubber to steel #15
Run a test with LOCTITE "Stick'nSeal ORIGINAL" waterproof adhesive available in a tube at Lowe's, etc. I used it over a year ago to glue down (with no fasteners) some 1/4" rubber matting on my 3010 Mule floorboard and it's still as tight as first applied-real sticky stuff-took a few days and a lot of hot soapy water to finally wear off of my fingers as I had no solvent to remove it during application.
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2025 AGT QHT500FL Stand-On Self Loading Dumper (A55787)
2025 AGT QHT500FL...
Bush Hog 10' Mower (A53314)
Bush Hog 10' Mower...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
