My Winter snow moving set up (with pictures)
   / My Winter snow moving set up (with pictures) #11
Hey Bill where did you get your cup holder from? Looking to put one in my Kubota. Thanks, Stanley
great pics... How is your heater plumbed?
The engine had two taps one on the outlet of the water pump & one on the engine near the t-stat. There was a short 3/8" hose just looped between the two. My hater core was 1/2". So I ran 1/2"ID heater hose most of the way then switched to 3/8" near the taps on the engine. I put a small ball valve on the outlet of the heater core to regulate heat & shut off the heat for the Summer. The 1/2" was REALLY hard to get through into the engine bay. I wished I would have used 3/8" instead & switched it at the heater core.
I made it. I took a piece of 3" PVC pipe. I cut a notch in it for a cup handle to fit in & rounded the edges. Then I took a 3-1/4" hole saw & cut a disk out of some heavy gauge sheetmetal & screwed it to the bottom. I mounted it with a short piece of 3/8" threaded rod & a plumbing split ring for 3/8" black iron pipe.
   / My Winter snow moving set up (with pictures) #14
You are all decked out my friend! Very nice.
   / My Winter snow moving set up (with pictures) #15
Very professional looking, thank you. Stanley
Another shot of the cup holder with a bottle of the best water on earth!
We finally ACTUALLY GOT SOME SNOW TODAY!!!
So it's time for a "1st impressions" report.
It was around 24 degrees out. The snow was light & close to sleet in consistancy. The wind was blowing pretty bad. I plugged the tractor in before I went out so it was already a little warmed up when I started it. Within 10 minutes of running it was nice & warm in there. I had a unzipped jacket on & a winter hat on but no gloves, no long underwear, no insulated pants just slacks & winter boots on. Overall I stayed plenty warm. I'd say it was about 50 to 60 degrees in the cab. I did have some annoying cold drafts. One area was along the edge where the doors meet the fender. For some reason on mine I have a 1/2" to 1" gap along there. When the wind blows you can feel it blowing on your leg or hand. The other area is down where the opening is for the diff. lock & the 4wd lever. This is about the only area I didn't seal off yet. It would be fine if I dressed up better I'm sure but my pants kept hiking up so my ankles were bare with cold air blowing on them.
The homemade heater worked pretty good but I wish the fan had a tad bit more kick.
The front window stayed cleared the whole time but hte rear did not. I had to wipe it off a couple times,..not a big deal but may try to do a flat rear window with a wiper for next year. I may jsut try some RainX for this year.
Overall the cab worked well I must say.
My raido I put in isn't loud enough to hear over a motor running a 560 RPM but is sweet when you drop the throttle down some.
The cup holder worked great!
The chute rotator worked slick but like I thought it really should be a little bit faster at turning. I'll fix that for next year it's fine for now.
I'll tell ya I really felt like a King in there! Oh & the dome light I put in is really cool!! I like that most of all I think because it was only $8 & is so nice to have in there. It was pretty cool when the wind started blowing the snow from the chute right back onto the tractor cab & I was in there nice & warm + dray like "Yeah,...whatever stuipid snow":cool:
Oh and the "Quick Fist" mounts for my shovel are junk AFAIC.:mad:
They should be called "Slow Fist" because they are a pain to try to get latched when it is cold out & you have gloves on. There's got to be a better design out there.
   / My Winter snow moving set up (with pictures) #19
great report... lol show that snow who's boss!
   / My Winter snow moving set up (with pictures) #20
Nice set-up. We have had around a half-inch of snow this season which I am perfectly fine with. However, I am sure more will be coming.
706075 LOT NUMBER 81 (A53084)
706075 LOT NUMBER...
2017 JOHN DEERE 8270R LOT NUMBER 189 (A53084)
2017 JOHN DEERE...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
