Slasher swing back blades binding up
   / Slasher swing back blades binding up #1
Parakleta
MF GC2400
I've just taken delivery of a new MF GC2400 with a 4in1 FEL and 4' slasher and I'm having some trouble with the slasher.
I was trying to adjust the slip clutch on the slasher but every time I engage the PTO one blade swings back and jams folded up. The vibration at this point is fairly severe and I shut down the tractor. I have to use a 3lb hammer to free the blade. I am engaging the PTO at minimum engine throttle.
The blade assembly is two parallel plates with two blades bolted between them, one at each end, and the top plate has the vertical shaft through it and welded. It appears the blade is riding up the weld and wedging between it and the lower plate. The lower plate is now bent and the weld is damaged. Both blades have done this.
I don't know if there is something misadjusted, or if I am doing something wrong, or if this is just an issue of faulty manufacturing or poor design. Anyone have any suggestions?
   / Slasher swing back blades binding up #2
or if this is just an issue of faulty manufacturing or poor design. ?
It could be that one or both are against you. Is it assembled correctly?
The blades should swing free and never jam up.
I don't know. It is now how it came from the dealer. I cut about 350 lineal metres when it was first delivered last night, and then went out today after I'd read all the manuals to check everything over and setup the clutch when the problem started. The manual for the slasher only says how to check the oil and adjust the clutch, nothing else.
The blades swing freely when I've unjammed them, the issue seems to be that when the shaft starts turning and the blades are stationary momentum is going to make them swing all the way back and they hit the bottom of the vertical shaft with some force.
Is anything supposed to limit the swing back at engagement?
   / Slasher swing back blades binding up #4
I have never seen one where the blades couldn't swing all the way around 360* . Seems strange to me they should hit like that but I am not familiar with that design. Sorry I can't be more help. Does it happen even when you engage it at slow speed and then increase speed slowly like you should ?
   / Slasher swing back blades binding up #5
The folding back part is normal, the vibration starting up is normal. The blades normally straighten out from the centrifugal force, and - once both are equally extended - the vibration stops (typically within 5-6 seconds). What's not normal is that it remains jammed. I believe that's related to the fact that the stump jumper is damaged. But what caused it in the first place is going to have to be between you and the dealer.
I'd first try to see if the dealer would fix it under warranty. If they refuse, take off the stump jumper and try to repair the damage. Hopefully that will stop binding the blade(s) in the first place. But you'll still have to learn to adapt to the initial vibration upon startup.
//greg//
What is a stump jumper?
   / Slasher swing back blades binding up #7
A photo is worth a thousand posts... Got one of yours???
Stump jumper is the round part that the blades attach to... in the middle.
You should be able to see from the photo that the bottom plate is now bent, and the dent where the blade has swung back against the end of the shaft.
   / Slasher swing back blades binding up #9
I haven't seen that design before but it is apparent how the blade could bind in that gap. Also, the blade could certainly not rotate 360 degrees.
If it were me, I'd weld a small piece of metal, maybe a large nut, onto the top of the blade about 4" or so from the attachment point to prevent the blade from rotating back into the gap. Some will not like this solution because of welding onto the hardened blade metal.
Rotate the blade until just before the bind point and decide where on the top of the blade the nut needs to be welded to prevent the binding. Do it to both blades to keep the balance.
Further, the mower (slasher) doesn't have a "stump jumper" and the head of the bolt is exposed to the damage that can be done on uneven ground. A quality mower has a rounded head on the bolt and is secured with a key in a reinforced shaft. Can't tell if that is the case from the photo.
If something is struck the blade will not rotate all the way out of the path but it wouldn't anyway with that design. I'd have to say that the design is not the best.
If it is possible to exchange that mower for a better constructed / designed one it would be advisable.
   / Slasher swing back blades binding up #10
I would be talking to the dealer about it. Either it is assembled wrong or it is a terrible design. Look at Tegs photo and you will see how the blades are able to swing freely.
   / Slasher swing back blades binding up #11
Yup, a picture is worth a thousand words. Had you posted that photo initially, the issue would have been clear to everyone. Instead of a stump jumper, there's a simple retainer bar. And as you say, it's clearly bent. Should be no problem to remove and straighten in a hydraulic press. What's more important is what caused it to bend in the first place. If you hit something, perhaps it will never happen again. But if the steel is simply too soft, it's a manufacturing/engineering problem - and you can expect recurrence. I think the test will be how easy or hard the steel resists the hydraulic press.
//greg//
   / Slasher swing back blades binding up #12
//greg//
The OP knows what caused, or is causing, the bend. The blades are swing back and getting stuck in the gap. The blade is acting as a lever.
Obviously, the blades have a bend in them that wedges into the gap (a photo of the blades would be informative).
The malfunction occurs when the PTO is engaged from stop and the blades don't rotate quickly to become extended. Not sure if the tractor has a way to gently engage the PTO and slowly bring it up to speed.
The mower is new and the problem has been observed from the beginning so it is not likely that something else bent the bar.
The solution is to determine how to stop the blade from sticking / entering the gap.
Parakleta can correct this observation if needed.
You can just make out in the photo the point where the blade is striking the weld, there is a slightly shiny spot about half way along the piece of the blade you can see in the photo. The blade has ever so slightly rounded corners.
The tractor is a MF GC2400 and I couldn't find any way to slowly engage the PTO, it seems to be on or off.
The manufacturer claimed that the bar was likely bent in transit and sent someone out this afternoon to fit a replacement bar. Engaging the PTO about 20 or so times since the new bar has been installed shows no sign of any damage to the new bar.
One specific difference this time from the previous is that I had started to adjust the clutch and so it now slips just a little on engagement and that may be enough to protect the plate from taking the full force of the swingback. I think it's a case of once the plate is damaged a little it's stuffed. The old plate actually had bits chewed out of it where the blade had swung back against it. It may also be the case that the previous one was softer or weaker than the new one.
I still don't like the design, but the problem seems to be fixed at least for now. I am tempted to get some kind of ablative or absorptive material to install between the plates, either timber or high density rubber (like the stuff that protects sledge hammer shafts from mis-strikes), to at least protect the weld at the bottom of the shaft (since this still takes the full force of the startup blow).
The unit is brand new and it's just starting summer so there's a few months of hard work ahead of it, so at least hopefully any problems will present themselves within the warranty period.
Thanks for everyones time.
   / Slasher swing back blades binding up #14
To engage my mower, I slow the RPM's to about half, my pto is either on or off but I still push the clutch in when I turn the PTO on, then ever so slowly let out the clutch... once it's up and running at half RPM's, I increase the RPM to reach the mark for 540 rmps.
It should be a slow engagement... and that's not just for the mower. The tractor itself is getting a shock load, too. Is the tractor new also? You mentioned adjusting the clutch... maybe it needs it more...
I slow the RPM's to about half, which is the lowest setting on the throttle. The tractor's transmission however is entirely hydrostatic and there is no clutch pedal. The PTO engagement lever doesn't seem to have a friction point that I can find, only on or off. The clutch I have been adjusting is the slip clutch on the slasher itself.
Is it possible that the sudden engagement of the PTO is some setting on the tractor that is not properly calibrated?
   / Slasher swing back blades binding up #16
Have no idea about that tractor so you might have a better chance of getting it answered over in the MF forum in a new thread....
   / Slasher swing back blades binding up #17
Sounds like you have an electric PTO clutch. I've got one on my John Deere. On those, there's no in-between. It's instant-on/instant off. But I think once you get that lower bar replaced, the problem should revert to how I described earlier; switch PTO on at low RPMs, put up with a little vibration while the two blades balance each other out, increase the RPMs, go to work. But quite honestly, it looks like a design that wasn't thought all the way through. Given that it's almost new, perhaps you could get the dealer to take it back in favor of one that's engineered a bit more sensibly.
//greg//
   / Slasher swing back blades binding up #18
You aren't doing anything wrong. That's kind of a strange mounting system-parallel discc with the blades in between the disks! That design is asking for problems. My mower has a single "stump jumper disk with the blade bolted to the rim. The blades have an offset that keeps them away from the stump jumper.
I have an independent pto and when I stop the pto, the brake stops the shaft and the blades "fold" under the stump jumper from their inertia. When I start up, the mower jumps due to the torque reaction as the blades "unfold". Perfectly normal.
I'd take the "slasher" back to the dealer and get a different design. As rough a usage as these devices are exposed to, you need one with a better design.
   / Slasher swing back blades binding up #20
The bottom plate is bent allowing the blade enough room between the plate and the hub to get wedged in there. You could take the plate off and flip it over to close the gap between it and the hub and that should take care of the problem. But if its new equipment I'd just take it back to the dealer and let them worry with it.
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
