Tried to help a friend out, but he helped me instead.
   / Tried to help a friend out, but he helped me instead. #11
There is that saying "If you lend a friend $20 and never see him again.....It was probably worth it. :)
post pics!
Here is the welder sitting on the welding table. I think that welding table is going to be awesome for my uses. You can see I don't have much room.
When I got into the welder it was a bit of a mess. In the end I got it put back together and welded a few beads on a piece of scrap. I think the feed is going to be a little poor until I get a new spool of wire in there, but it welds good. It's a Millermatic 135.
The drill bits are a loss. They are morse taper, but the taper is MUCH larger than my MT2 drill press spindle. These are probably twice the size. They are a little corroded, too. I may find a home for them, but I don't think I'll be able to use them.
   / Tried to help a friend out, but he helped me instead. #14
My dad owned a used car lot in the bad part of Dallas. The beggars would come in every day asking for a loan. Once my dad would loan them $20, he never had to worry about seeing them again.
   / Tried to help a friend out, but he helped me instead. #15
You can get morse taper adapters to use any size bit with your MT2 spindle. The adapters are cheap, so if the bits are of a size that is useful to you, keep them and get the adapter. Especially if they are American or British bits (far better than those asian bits).
   / Tried to help a friend out, but he helped me instead. #16
Nice welder bud, I bought my dad same one for christmas few yrs back. Put in a spool of clean wire, new tip, new cup and you should be good to go. If wire feed problem still exists look into a new liner, and go over the drive roller tension and just make sure its not slippin from a tight spool of wire. Good luck!!!
Interesting. Is there some way to measure what I have and determine what taper it is?
   / Tried to help a friend out, but he helped me instead. #18
   / Tried to help a friend out, but he helped me instead. #19
Great advice !
I had a Miller 135 a few years ago, very nice 110 MIG welder. I sold it when I got my 180, I wish now I'd kept it.
Try setting the wire feed tension around 3 or 4 (if my memory is correct) and clean the grooves in the feed rollers. The 135 has a reversible feed roller, one side is for .023 wire, the other side is for .030-.035.
You should have the spool tension just tight enough that the roller has to pull the wire off and the spool won't turn by itself.
Sean
Not the best, but there is a chart here with dimensions for different style chucks and tapers.
For what it's worth, here's a picture of a MT3 that I use in the tailstock of my lathe, it measures out about 4" long and .947 at the big end.
Thanks.
I'm pretty sure these new bits are MT3.
I dug through the bucket and found three bits with MT2 ends on them and two more that had normal straight shanks. One of the bits with a straight shank has a hole in the shank and holes coming out the bottom of the drill bit. I assume this is for a lubricating system. Having these five bits will probably save me what I offered the guy for the drill bits originally. If I had to go buy all five bits new, they'd cost probably twice what I paid him. They are sizes that I'll probably use.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Toro Zero Turn (A50324)
Toro Zero Turn...
2025 CFG Industrial STSD10 (A50123)
2025 CFG...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
Kubota BX2230D (A47384)
Kubota BX2230D...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
