2 Cycle fuel in a 4 Cycle engine
   / 2 Cycle fuel in a 4 Cycle engine #1
Wayne County Hose
Wayne County Pa.
Massey Ferguson model 85, Allis-Chalmers WD-45
I have a Honda 5.5 hp powered air compressor in my service vehicle, 4 stroke engine. I also have a little 2 stroke generator which was given to me. I really don't want to carry 2 types of gas as I also carry kerosene for my torpedo heater. Can I use the 2 cycle fuel in the Honda with no ill effects? Thanks!
   / 2 Cycle fuel in a 4 Cycle engine #2
Yes you can, but cost?
   / 2 Cycle fuel in a 4 Cycle engine #3
You will probably foul the spark plug and rapidly build up carbon in the cylinder. I would NOT burn 2 cycle fuel in a 4 cycle engine.
   / 2 Cycle fuel in a 4 Cycle engine #4
Why not carry just regular gas and then add a dash of oil directly to the tank when filling it up?
These little 2 cycle Chinese Generators are tough to kill. The motors are bullet proof for the most part so running a synthetic 2 cycle oil will not require a exact mix.
Chris
   / 2 Cycle fuel in a 4 Cycle engine #5
Maybe at 20-1 or 16-1 but today's two stroke formulations burn cleaner than you think. I have a 20 hp lawn tractor that gets all my stale fuel, mixed fuel and other stuff I have to drain out of motors I'm fixing and it runs fine on the same plug it has had for at least three years.
   / 2 Cycle fuel in a 4 Cycle engine #6
I'll continue to keep a small 1 gallon container of mixed oil for my 2 cycle stuff and run clean fuel in my 4 cycle equipment. I have no reason to run any oil mix through it.
   / 2 Cycle fuel in a 4 Cycle engine #7
Next door neighbor said he junked his 2 year old walk behind lawnmower this past Spring because his wife put the 2-cycle mix he had for a string trimmer in his 4-cycle lawnmower and he could no longer start the lawnmower.
Personally, I suspect the mower could have been fixed but he had already gotten rid of it when he told me about it.
   / 2 Cycle fuel in a 4 Cycle engine #8
More than one time I found myself out of gas on a week-end day, needing to till or mow, and no gas. I have used 2 cycle mix with no ill effects, can't see a bit of oil hurting things that much, a little "top-oil".
   / 2 Cycle fuel in a 4 Cycle engine #9
A really rich mix will make it hard to start. More modern engines will be worse, but it won't really hurt anything, synthetic oil and leaner mixes obviously being less of a problem. A 50:1 mix might increase pollution but it would probably be no worse than running a few ounces of Marvel Mystery Oil in the gas.
It really isn't that hard to keep a seperate container though. I have an old Lawnboy which I run at 32:1, I just use the same mix in my McCulloch 440T chainsaw ("The Professional" as I call it), my string trimmers and my leaf blower, most of which call for 40:1 or so. Its a little rich and they might be a bit harder to start. "The Professional" smokes like Texas Chainsaw Massacre on that mix, but it runs fine otherwise. I cut some massive logs with it and while I filled the yard with smoke I noticed no problems, on cooler days it requires a bit of carb cleaner for the initial start.
I actually have a proportionally large amount of 2 cycle equipment and only keep the one gallon mixed at 32:1 regardless of what is called for and run that in all of them and mix more as needed (mainly because the Lawnboy will see the majority of use) and I really can't have a few gallons of close mixed fuel around for less frequently used equipment.. At current count I have the Lawnboy, the chainsaw, 3 string trimmers, the Toro s140 snowblower (more like a gas version of an electric shovel) and the leafblower. I may even buy a gas hedge trimmer but I'd use the same mix.
I may, if I needed to get rid of it, run extra two cycle stuff through the 11hp Briggs IC engine on "The Beater", a crappy Agway tractor I picked up mainly to help in the disposal and removal of fall leaves.
   / 2 Cycle fuel in a 4 Cycle engine #10
I have been using a 50:1 mix in all my power equipment. I started doing that in 1983 when I started my lawn care biz.for the same reason ,one can of gas for all. now I mix 20 gals at a time .I put it in everything Atv,tiller,genset,ect every thing gets filled up at the end of day; ready for tomarrow I have even put it in my wifes truck scince she cant seen to read a gas gauge
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
