What did you do to your tractor today?
   / What did you do to your tractor today? #31
Well I gave mine a break today we had a busy day yesterday what with running over my saw and all yesterday.
   / What did you do to your tractor today? #32
What I did "to" my tractor... Ran the bloody thing out of fuel again :mur: I really need to replace the crappy kubota fuel gauge #$%^&*
What I did *with* my tractor... Chipped branches till I worn my butt out... getting old sucks. I *need* to do some greasing tomorrow!!!
   / What did you do to your tractor today? #33
Changed oil & filter , changed fuel filter & cleaned bowl , greased , and filled with fuel . 1,302 hours .
Started making the new muffler as the gay factory one was rotten
   / What did you do to your tractor today? #35
Moved 12 fence posts, augered 7 holes(which quickly filled with water) and put in place some rails. Waiting for ground to freeze to finish repair on fencing. My timing is always off - too wet, too busy etc. Today felt like spring but we had a wind chill of minus 8 celsius.
Will finish on the weekend.
   / What did you do to your tractor today? #36
Yeah, what didn't I do to it?:(
Took the carb off and drained the water out - again. Did it yesterday but forgot about the tank.:eek:
Drained the tank - more water!:(
Put gas in and tried to start it -killed the battery.:confused:
Pulled the spark plug - no spark. Tried with another plug - it was good, whew!:)
Peeled off to town and picked up new plug and a fuel filter. Put them in and now I'm waiting for the battery to charge and my blood pressure to settle down.:cool:
Did you find out how the water is getting in the tank?:)
   / What did you do to your tractor today? #38
I did the hydraulic fluid and filters on my L4400HST today. I drained the fluid into the lower half of a white plastic drum. It was pretty clean looking.
The magnet on the suction side filter was pretty clean too. I used the new USDTII hydraulic fluid. It is noticeably quieter.
I also split a 1.5 inch pipe and welded brackets on it for my FEL so I don't mess up my gravel when I remove snow (if we ever have any).:thumbsup:
   / What did you do to your tractor today? #39
My son is visiting from Virginia so HE, stock piled #2 stone, moved 2 logs, graded a couple of high spots in the lawn and moved 20 concrete blocks.
I leaned on the shovel and supervised. It is good to have him and our daughter in law home!
   / What did you do to your tractor today? #40
I'm almost afraid to ask.
Greasing the tractor..........or the worn out butt???:laughing::laughing:
On a side note......I did nothing 'to' or 'with' my tractor today.
2025 Platform Safety Basket Attachment (A53421)
2025 Platform...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
New JMR 40" Mini Skidloader Flat Bottom Grapple (A50775)
New JMR 40" Mini...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2018 FORD F-350 (A55745)
2018 FORD F-350...
