Mulcher Heads....What you runnin and WHY?
   / Mulcher Heads....What you runnin and WHY? #21
I thought that Cimaf could only sell excavator heads and could not sell any for skid steers or CTL's..... I know that they lost the lawsuit with gyro trac. Did something happen that I missed?
   / Mulcher Heads....What you runnin and WHY? #22
Cimaf has came out with generation 3 heads the rotor is slightly different from the cimaf/gyro trac rotor. So there suppose to be able to sell the gen. 3 in the states.
   / Mulcher Heads....What you runnin and WHY? #23
Sorry if I posted some mis-information. What do the new gen 3 heads cost?
   / Mulcher Heads....What you runnin and WHY? #24
I'm always amazed to see how facts often get distorted or reduced. So, to get things straight:
1. See in attachment the joint press release that Gyro-Trac and DENIS CIMAF issued back in December 2008, after they settled their dispute. The extra subtleties of the contract that was then signed are confidential.
2. I would like to invite anyone who receives partial information - such as what tuckinlugz received - to send me an email at frederic.denis@deniscimaf.com, giving me details of what they were told, and by whom.
3. As for the generation-3 heads, they are pre-production models using a completely new technology, different from the "technology developed by DENIS CIMAF" at the time of the signature of the settlement agreement.
  • CDP 20081212 en DC vs GT Settlement.pdf
   / Mulcher Heads....What you runnin and WHY? #25
I believe that I read this information on this site. I re-read the letter in your post as it seems like does say that DF can not make heads that attach as front mounted units ie skid steers etc. using their technology.
As for making a "new" technology, I was unaware of this.
Thanks for the info!
   / Mulcher Heads....What you runnin and WHY? #26
Anyone have an opinion on skid pro rotary cutters? skidpro.com
   / Mulcher Heads....What you runnin and WHY? #27
297 just run the 180D although the motor is a little small it works just fine. I ran one on my 148 for a year and no problems at all. The motor runs out of displacement pretty quick so the difference between min and max are not as apparent as with the smaller hp machines but it worked for us.
   / Mulcher Heads....What you runnin and WHY? #28
Robbie, told me it was impossible to run the 180d on the rayco without causing damage to the motor on the 180d. Did u upgraded the pulleys? Are U still running the cimaf on the 148? Bet it's amazing on it, got any videos of it running would love to see it in action with the 148.
   / Mulcher Heads....What you runnin and WHY? #29
Nope pulleys and all the same. The 148 doesn't put out nearly as much hyd flow as advertised all the time. It ran fine, like I said it would have been nicer to have a 160-180 cc motor but they don't fit in the housing. You are definitely stretching the 107 on there but..... It's up to you. It does cut very good on the 148.
   / Mulcher Heads....What you runnin and WHY? #30
The 148 burnt this spring so it's not running no more but it was a nice little machine. It had its issues same as them all but that's not the topic here. I don't intend to replace it as I have no use for any machine under 250 hp any more. Good luck.
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
