What did you do to your tractor today?
   / What did you do to your tractor today? #31
Well I gave mine a break today we had a busy day yesterday what with running over my saw and all yesterday.
   / What did you do to your tractor today? #32
What I did "to" my tractor... Ran the bloody thing out of fuel again :mur: I really need to replace the crappy kubota fuel gauge #$%^&*
What I did *with* my tractor... Chipped branches till I worn my butt out... getting old sucks. I *need* to do some greasing tomorrow!!!
   / What did you do to your tractor today? #33
Changed oil & filter , changed fuel filter & cleaned bowl , greased , and filled with fuel . 1,302 hours .
Started making the new muffler as the gay factory one was rotten
   / What did you do to your tractor today? #35
Moved 12 fence posts, augered 7 holes(which quickly filled with water) and put in place some rails. Waiting for ground to freeze to finish repair on fencing. My timing is always off - too wet, too busy etc. Today felt like spring but we had a wind chill of minus 8 celsius.
Will finish on the weekend.
   / What did you do to your tractor today? #36
Yeah, what didn't I do to it?:(
Took the carb off and drained the water out - again. Did it yesterday but forgot about the tank.:eek:
Drained the tank - more water!:(
Put gas in and tried to start it -killed the battery.:confused:
Pulled the spark plug - no spark. Tried with another plug - it was good, whew!:)
Peeled off to town and picked up new plug and a fuel filter. Put them in and now I'm waiting for the battery to charge and my blood pressure to settle down.:cool:
Did you find out how the water is getting in the tank?:)
   / What did you do to your tractor today? #38
I did the hydraulic fluid and filters on my L4400HST today. I drained the fluid into the lower half of a white plastic drum. It was pretty clean looking.
The magnet on the suction side filter was pretty clean too. I used the new USDTII hydraulic fluid. It is noticeably quieter.
I also split a 1.5 inch pipe and welded brackets on it for my FEL so I don't mess up my gravel when I remove snow (if we ever have any).:thumbsup:
   / What did you do to your tractor today? #39
My son is visiting from Virginia so HE, stock piled #2 stone, moved 2 logs, graded a couple of high spots in the lawn and moved 20 concrete blocks.
I leaned on the shovel and supervised. It is good to have him and our daughter in law home!
   / What did you do to your tractor today? #40
I'm almost afraid to ask.
Greasing the tractor..........or the worn out butt???:laughing::laughing:
On a side note......I did nothing 'to' or 'with' my tractor today.
Two Post Car Lift (A50120)
Two Post Car Lift...
2025 60in Forks and Frame Skid Steer Attachment (A55787)
2025 60in Forks...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Skid Of Metal T Posts (A50775)
Skid Of Metal T...
2004 New Holland TC55DA Tractor (RIDE AND DRIVE) (A50775)
2004 New Holland...
