RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,190
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
I know it is your building and all the experts will run away when things go wrong.
I work with a friend who wanted to build a glass roofed awning over his back deck.The glass roof was to be 7' out by 16' long on a 2 //12 pitch .
He has a chemistry degree which made it worse because he knew he was smarter than the average bear.
It took me 6 months of planning at many lunchs sitting on the computer all having fun to design 2 holes to support his awning.
He wanted easy
PT 4x4 = no
PT 6x6 with cement around = no
steel 3x3 thinwall cement around = no
So this went on for weeks, we even had some in the shop say they would come over and dig the job to shut us up.
So for everyone of his quickies I said PROVE IT with pictures and building code practices.
I FINALLY WON, poured sono tube cement deeper 3 pieces of rebar, footer ,4 1/2" bolts at 6" above ground level to a plate with 4"x4" steel tube by 12' tall.
I LOST ON the top plate he wanted to notch the tubing to hold the double 2" x 10" beam.
When he cut the tubing notchs the tube tops went BANANA because tubes are rolled and welded.
I consulted on half of his kitchen remodel that was contracted.
I consulted on the driveway interlocking that was contracted.
We are now debating motion sencing lights.
The biggest fun that comes up is that he says ( Ok you know the light at the front door), and I answer NO I have NEVER been to your house except on paper every lunch hour.
He failed the Emission Test P0300 ( random cross fire ) and curb idle high CO. I am changing his plugs on paper, egr , cat ,code reader.
It keeps me out of trouble at lunch time.
Do you serve LUNCH?
Craig Clayton
That's all well & good, but if you don't get below frost depth, ANYTHING will heave, period.
