Which One?
   / Which One? #1
Liltex10
Who knows
I am at the beginning of researching on a tractor. Have run a Kubota L series(35hp) not sure which model. I am purchasing a farm and will be farming @ 200 acres. Small grain such as corn or wheat. Any recommendations for a new farmer on tractor and implements you would suggest I need. Any comments would be much appreciated.
LT
   / Which One? #2
LT
I would go atleast 9540 with 4x4
   / Which One? #4
How many acres you gonna plant?Mow? I thinking all the way up to the M135x if your gonna do alot.Gonna really depend on what size equipment your wonting to use.
   / Which One?
I won't be mowing any acres. Anything that is not planted will let grow for cover for pheasant cover. So basically the tractor will be used primarily to plant the small grain on @ 200 acres. When I was in TX we always plowed, then tilled then broadcast spread oats in three different moves. That was much smaller planting acreage for food plots. Here(MT)I will actually be trying to have some farm income off the grain while targeting increased pheasant and geese numbers. Would love to get away with something smaller but I'm sure I have no idea how long it would take me and how much I am fixing to learn. What is your opinion of the implements that do tilling and planting in same step?
LT
   / Which One? #6
LT
Man,I wish i was in your shoes. I havent ever planted that many acres,sure someone will join in. But sounds like sure gonna need some HP.My neighbor pulls a 21 ft finish disc with 125hp/4x4 NH.I see alot of folks going to the no-till drill for wheat.If your going to plant corn,how many row planter you wonting to use? You going to harvest by combine yourself or higher done?
check out Youtube.com type in tractors no-till drill or something
   / Which One?
Yeah until you have to pay 7% state income tax. Then I wish I was in your shoes. I'm learning so I have no idea how wide or rows I can go. I would hire out the harvesting for a while. Might even lease the land out this first year and work out where I am the helper to learn the ropes. Thanks for the YouTube I will take a look.
LT
   / Which One? #8
LT
Probaly good idea leasing it out,cost you alot more $$$ getting everything purchased. Just raise cattle and hay here,few big deer food plots.Me and neighbor been talking about doing 50acres in corn but thats it.Without any rain this summer,havent done much finally getting some rain,tilled up 25ac.today that the hogs have torn up,and drug it down,things kinda slow right now.
   / Which One? #9
you can go with a M9540 on up to an MX135.any of these will pull a plow disc notill drill.
   / Which One? #10
Doesn't give your location - that makes a huge difference. Best thing is to talk to farmers in the area to gain knowledge as to what works. Three colleagues I worked with had about the same amount of land that you have, also use their land for pheasants and other hunting, but share crop their land because of the equipment investment to do the job right. They are Northeast Nebraska, Northwest Iowa, and Southeast South Dakota, all primarily corn. Case IH and Allis-Chalmers/Deutz-Allis/Gleaner, the farm equipment companies for whom I worked, did their field testing by supplying combines to custom harvesters or very large farmers. I got to travel with those guys from Texas to Montana, then Illinois to Mississippi. One thing they all liked to do when the crop was green or the weather was bad was sit in coffee shops and talk shop. I learned things like guys who moved from the south to the upper midwest tried the same farming practices they were accustomed to, went broke. That wasn't always the case. Some who moved from one area to another found the opposite. You really should get acquainted with farmers in the area to get an idea. Even things like a planter - you might be able to get a great deal on a 36" row spacing planter for example and then find that none of the custom cutters in the area can handle that spacing and you're screwed.
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
1268 (A50490)
1268 (A50490)
40'' root grapple (A53421)
40'' root grapple...
