L4850, BF900
   / L4850, BF900 #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Hi, looking at a '92 L4850, will this loader from my '91 L4150 fit it? Also how about my Laurin Cab? Bodies look similar, but the other tractor is quite a distance from me so I can't visit personally right now. Any thoughts? Thanks!
   / L4850, BF900
How about this, which loaders are generally on the L4850?
   / L4850, BF900 #4
Yes, the L4850's normal loader was the LA1150 - but a BF900 will fit and work fine. The Laurin cab will fit too.
Also, the ROPS from the L4850 will fit the L4150. The Laurin's axle-to-fender ROPS supports may be the heavier type - if so they can be swapped to stay with the cab.
   / L4850, BF900
Thanks much, it might be a good swap, the L4850 is low hrs and the floor boards and fenders look mint, give me a change to rehab the old 4150, which works great but is very rusty. Thanks again for the info.
   / L4850, BF900
Hope it hasn't sold!
   / L4850, BF900 #7
One nice difference you'll notice is the L4850's Ever Clutch - which doubles as the Hydraulic Shuttle. The valving was improved to be more gradual. It gives soft shifts even with engine rpm well above idle. Swapping over a cab and loader takes some wrenching - but it's quite possible to do. The Laurin is heavy to handle - weight is less without the doors and hinged windows.
On my rig the loader valve extended thru the front of the Laurin, making the loader non-removable. I re-mounted the valve to the cab with disconnects so now the loader comes off easy - and the valve can be used for the snowblower.
If you're anything like me you'll want to keep both tractors. I had an open-station L5450 that I sold - but I've missed it. I like the cab for everything except backhoe work - the open station is handier. Take care, Dick B
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
