FYI- Rimguard cost - Rocky Mtn West
   / FYI- Rimguard cost - Rocky Mtn West #1
Trails2004
Gold Member
Outside
2009 JD 3520
I just had my JD 3520 drive wheel tires (15x19.5 R4's) filled with Rimguard the cost was 3.35 per gallon. They added 29 gallons per tire ( 310 lbs )
The other local tire shop was pushing CaCl2. When I asked if this product was safe to use- they replied a tube is recommended--- So I guess it isnt all that safe if they want you to buy tubes :laughing:
   / FYI- Rimguard cost - Rocky Mtn West #2
And?????:confused2:
   / FYI- Rimguard cost - Rocky Mtn West #3
Hmmmm, I think they saw you coming. The R4s on my 3720 are 43-16-20 rear and 27-8.50-15 front. I was billed $237.60 for all four just this past summer; 36.5 gallons each rear, 7.5 gallons each front. 88 gallons total, at $2.70/gal installed.
//greg//
And?????:confused2:
My post was merely an FYI regarding the cost of Rimguard in the Rocky Mtn West AND the continued miss information on Calcium Chloride .....i.e.- it is safe but you better use a tube........
//greg//
You must be a tad closer to the supplier??? We have a significant sugar beet crop in the Rocky Mtn Region....they must ship all the juice east..... :laughing:
   / FYI- Rimguard cost - Rocky Mtn West #6
I didn't know if you were asking a question or stating a fact... I was told they use calcium with tubes do to rust. :D
I'm sorry Murph..I didn't thoroughly illustrate my sarcasm ......
   / FYI- Rimguard cost - Rocky Mtn West #8
Sudite :cool:
   / FYI- Rimguard cost - Rocky Mtn West #9
Rimguard here in Idaho runs about $3.50-3.75 also...guess were just more expensive here in PNW.
i had CaCl in my old JD tires, and also used tubes. Had rust issues on both rims I also had one tire explode and destroy three (3) 4x8 foot sheets of 16g and 12g steel (total rust overnight). Started to do a number on the shed siding also.
This time i opted to go with rimguard. Id rather my shed look like a crime scene if the tire ruptures instead of rusting out everything. If i was one to park the tractor OUTSIDE of my shed, id probably of used CaCl as its cheaper.
Rimguard here in Idaho runs about $3.50-3.75 also...guess were just more expensive here in PNW..
I'm in one of the "square" states to your southeast :D So at $3.30 per/gal sounds about right- if they are shipping from Michigan
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A54607)
2020 FREIGHTLINER...
CATERPILLAR CB24B SMOOTH DBL DRUM ROLLER (A52705)
CATERPILLAR CB24B...
UNUSED 3 PRONG HAY SPEAR (A54757)
UNUSED 3 PRONG HAY...
2014 MOROOKA MST3000VD TRACK DUMPER (A52705)
2014 MOROOKA...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
