pto wont engage
   / pto wont engage #1
dave1550
new holland/ford 1925
i have a 1999 new holland model 1925 rear pto stopped running when i was bush hogging mid and rear pto do not engage
   / pto wont engage #3
Welcome to TBN!!
There is a New Holland forum, and those folks may be able to help you.
However...did the PTO just stop? Or, did you hit something?
When you write "mid and rear pto do not engage", do the levers move (or is it an electric engagment)?
A little more information may help in figuring out the problem...
   / pto wont engage
the pto just stopped didnt hit anything
both of the levers move fine
   / pto wont engage #5
Read any troubleshooting tips in your manual.
First (and easiest) is to get under the tractor and look for broken or disconnected linkages...you could have snagged something when brush cutting.
   / pto wont engage
all the linkages are ok
   / pto wont engage #7
Are your PTOs actuated strictly by linkage? Is there any electrical switches in the system?
I was hoping you had an easy fix...but unless there's an electrical problem (fuse or relay), you might be looking at tearing into the transaxle.
You have a Shop Manual, by chance?
   / pto wont engage #8
WELCOME to TBN :)
I moved your thread to the New Holland Owning/Operating Forum.
   / pto wont engage #9
first off please dont double post it makes it hard for people to keep track of, i answered in your other post and will answer agian. It is most likely the pto sprag clutch that is inside the rear end if you have a 9x3 trans the clutch is really just a bearing with flat sides inside of a collar that spens out and tightens up against the colar you i just had a 1715 i worked on with the same problem and thats what was wrong. Also this is not a job you will wont to tackle at home since you have to split the tractor between the trans and rearend then remove the lift top both final drives and ring gear to get the clutch mech. out
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
Toro Groundsmaster 400-D (A57453)
Toro Groundsmaster...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
2014 Lincoln MKS Sedan (A56859)
2014 Lincoln MKS...
1459 (A57192)
1459 (A57192)
