What is this threaded boss on my ROPS?
   / What is this threaded boss on my ROPS? #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
See attached pic. I was looking for somewhere to mount work light brackets, and this seems like a convenient place if I can get a stubby bolt. I am guessing it may be intended for a bolt to snug up the ROPS to prevent rattles, but really have no idea. Any thoughts? And does anyone know offhand what the thread size/pitch is? I haven't yet tried fitting bolts in there, but if it's metric I wouldn't have one anyhow. Thanks!
   / What is this threaded boss on my ROPS? #2
This is used as a stabilizer bolt for the ROPs. On my B3200, without this bolt, the top 1/2 of the ROPs shakes as there is a little play in the hinged area. This bolt tightens that right up.
   / What is this threaded boss on my ROPS? #3
Sounds like killing two birds with one stone. One bolt to mount a set of work lights and eliminate free play in the top of the rops at the same time.:D:D
   / What is this threaded boss on my ROPS? #4
It is metric, and I think this is what it is 10-1.25 mm
But it has been a while so I cannot be sure.
James K0UA
   / What is this threaded boss on my ROPS? #5
It is true you could use it for that. Personally, I like my lights higher up as they have a wider dispersion.
   / What is this threaded boss on my ROPS? #6
You don't necessarily need a 'stubby' bolt. You can use a long bolt, and just add nuts to hold the brackets and keep bolt tight to the welded nut.
   / What is this threaded boss on my ROPS? #7
On mine it is a Metric M10 1.25 pitch.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
