Blind Spot/ Hot Spot mirror removal
   / Blind Spot/ Hot Spot mirror removal
Two possible removal items, I had but didn't think of, were dental floss (prompted by fishing line suggestion) and a double edge razor blade.
Less than 15 seconds of seesawing with dental floss splits the paper back to get the mirror off and about 30 seconds of double edge razor work cleans the mirror.
At my age I don't like lengthy projects nor do I buy green bananas.:D
Thanks for all the ideas.
   / Blind Spot/ Hot Spot mirror removal #12
I really like the fishing line idea, thanks for sharing that!!! :thumbsup:
For those who don't fish, masons's line would likley work well too. Not sure about dental floss...
I suggested it...
I suggested it...
Good for you and thanks.
The reason for the change - I found that some are now made that are adjustable and it be paramount the old man I keep up with technology. Ok, OK so maybe they've been available for 20 years and I am just behind that far.:D
   / Blind Spot/ Hot Spot mirror removal #14
Best goo remover I've ever found is naphtha. It comes in a can at Wal*Mart marked "Zippo" or "Ronsonol" lighter fuel.
   / Blind Spot/ Hot Spot mirror removal #15
Too flammable for my liking. What paint thinner will not remove, I use "Goodbye Splatters" which comes in a can from Aco Hardware. Label says "contains Xylene and will damage most plastics and automotive paints" but I have used it to remove deck stains from vinyl railings and it doesn't seem to damage them much.
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
200387 (A51247)
200387 (A51247)
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
