Looking for some help, I've posted on Yanmars boards, but really need advice.
My ym2000 pops out of high range when under load. Lets say i'm pulling my brush hog, not mowing, it will jump of of high range. I opened up the shifter box and the forks appear intact, and the gears look fine to me although I am clueless as what I am looking for as far as damaged gears etc.. It also has never been able to shift into all gears since I picked it up. This weekend I pulled the shifter assembly off, checked things out, lined up the forks and the gears and it was running fine. Was able to shift into all gears, and it didn't pop out of high range. The next morning I put my c-tine cultivator on to work up the pumpkin patch, and it ran fine for about 15 mins or so. when I stopped the shake off some extra vegatation from the cultivator, the only gear that worked was 1st and reverse was in the neutral spot... help. Pics of gear box and forks below. Are the forks suposed to move easily up and down the shafts? Mine do not however I can feel when they pop into the grooved area of the shaft. Also how do you get to the ball and spring, I assume you pop out that pin, which way... sorry I am completely clueless when it comes to mechanical stuff.
