My new Kubota with Air ride seat
   / My new Kubota with Air ride seat #41
Yep. According to the photo the fore/aft is included. There is no OPS on this seat but i dont care about that. The Grammer I ordered has the same size base size and height as the OEM one but the floor has to be level for it to work so I have a small mod I need to do on the floor.
Did you ever price up the OEM seat? Shocking to say the least. If you anyone had to replace there OEM seat the OEM system will cost you just for the seat portion $1549.40. Then if you need the lower suspension system then that will cost you another $869. :shocked: I think we got a deal lol
I did hit a snag on my air ride seat. The dealer i ordered the seat from said everything was in stock so we paid for it then they called back a few hours later and said they can't find the right arm rest in there stock so I told them not to ship the seat until they have all the parts. Now it will be a month before I get it.
They also told me to get the heated option it would cost an extra $300 and take at least 45 days so I'm passing on that and will add the heated option myself for 1/3 the cost. I'll have a thread on the full installation including adding the heated option when I get it all.
4shorts, as usual I and I'm sure many others are looking forward to air ride seat modification
thread!
Stu
4Shorts. On the seat I got I all so had the option for heated back to......since I have a cab tractor with a great heater I did not think this option was worth it to me.
   / My new Kubota with Air ride seat #43
thread!
Stu
Thanks Stu. Glad to hear your looking forward to the thread. It should be a little different than what I usually do but adding the heated seat elements and a slight mod to the floor should keep you from dozing off :laughing:
Yes I would agee that it's really not a necessity but I do have heated seats in my other vehicles and use them all the time. Even in the summer there used. I find it soothing on the back. I could have ordered the option with this seat but it would take 45 days or longer to get the thing. Right now I'm just waiting three weeks and I will be adding the heated option myself. Grammer wanted $300. For the option and I can buy an aftermarket kit with a two year warranty for $100. So I figured it's worth it.
   / My new Kubota with Air ride seat #44
I'm thinking about using this seat in my L5030 and looking at the Kubota bracket it looks like you could use spacers to get the new seat level instead of cutting ...what do you think?
The seat and pan I used worked out very well for having the seat level. I do not slide forward any more which is a big plus for me.
   / My new Kubota with Air ride seat #46
In my case and the seat I used if you use spacers instead of cutting the pan the seat will be to high. It would add 2" in height. I'm order to get away with just using spacers you'll need a low profile seat (forklift seat ) similar to the one DDT used.
   / My new Kubota with Air ride seat #47
Thanks for the reply...I just ordered a Grammer MSG95G Air Suspension seat, I looked over all the dimensions and looks the same as the MSG75. What did you do with the PTO/engine kill switch under the original Kubota seat
   / My new Kubota with Air ride seat #48
The Grammer seat model I used is MSG-93-721. When I removed the original seat I re-mounted it in an old Zetor tractor for a customer of ours but before I did I removed both switches and integrated them onto the Grammer. It was no easy task but I get it done :)
YouTube - Kubota GL5740 with Custom Installed Grammer Seat..wmv
   / My new Kubota with Air ride seat #49
Has anyone heard if Kubota is offering an air suspension seat for the Grand L yet? They did release one for the M narrow so I would hope they could do something similar for you Grand L guys since we both have the same basic narrow cab. Of cours I think Pauls seat is a lot better then the Grammar MSG-75 that Kubota offers for the M narrow but it is still better then the stock one that came in mine.
   / My new Kubota with Air ride seat #50
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
20702 (A51694)
20702 (A51694)
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
