Mal new member - Australia
   / Mal new member - Australia #1
malfuller
Queensland, Australia
mccormick gx50
:confused:Hi !
I have just joined this forum today, I have a McCormick gx50 with many problems . Looking for help to get it back up and running.
Also look forward to be able to help others if I can
Cheers
Mal
   / Mal new member - Australia #2
Welcome to TBN. :)
   / Mal new member - Australia #3
Greetings to the fella from down under...
thanks for the welcome murphy1244
hope someone out there can help?
the motor will crank if i hot wire it but the motor still wont start,the solenoid in the injector pump wont open to let fuel through.
the only thing that has been touched are the diff locks, the solenoid for the diff locks appears to be on the same circuit as the stop start solenoid (which i have replaced) in the injector pump,
no dealer within 200 mile and cant get any help
cheers Mal
   / Mal new member - Australia #5
Welcome!!
Try posting your question in the Brand Specific / McCormick forum. I am sure someone that hangs out there will chime in.
Good luck with your project!
   / Mal new member - Australia #6
cheers Mal
I am not really knowledgeable about your particular tractor model.....but my first impression is that some safety switch is not closed.......seat.. clutch... etc That's why when you hot wire the starter it cranks but the fuel solenoid does not open. Check your safety interlocks one at a time (bypass them one at a time until the tractor starts in the normal way.
G'day from South Australia
   / Mal new member - Australia #7
Welcome to TBN from Missouri.
   / Mal new member - Australia #8
Welcome, You do have to be resourceful to repair it when the nearest dealer is over 200 miles? We have several within 20 miles of us..Do you have a diagram or manual of the circuits and wiring?
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2016 KOMATSU PC360LC-11 EXCAVATOR (A53843)
2016 KOMATSU...
