Mowing TC-30 belly mover
   / TC-30 belly mover #1
Elviscaretaker
Gold Member
Idaho
New Holland TC30/ Same Duetz Fahr 5110
Any thoughts about using a TC 30 for mowing using a belly mower?
About 5 acres of grass with hills and such, some with pretty steep angles.
What I'm wondering, is this too heavy for a nice cut without "rutting" the yard or should I just find a good riding mower for this job?
I have the tractor, just bought the property and the thought of trying this with my current mower (21" walk behind) is not a very pleasant thought! Would take me a week and I'd like to do this painlessly and in under a day but at the same time, want the yard to look good etc.
Thoughts?
If not a belly mower then any ideas on a rider that could handle this? Most seem to be rated at 1-2 acres...
Thanks!
   / TC-30 belly mover #2
I use a 1030 with a 6ft finishing rear mower for my lawn and a TC55DA with a 8ft rear finishing for my fields. You couldn't tell that I mowed with a tractor vs a lawn mower. I don't really like big heavy belly mowers... but that is preference.
   / TC-30 belly mover #3
I also use a 6 ft finish mower on the 3 point in the open areas but prefer a riding mower in the more confined areas around the house. A riding mower works better around trees, bushes etc.
   / TC-30 belly mover #4
I use a 6' finish mower on the tph for every thing except right arround the house. I made sure the finish mower and the riding mower are set at the same hieght. what tires do you have and are they loaded.
Bill
   / TC-30 belly mover
By finish mower do you mean a reel mower? 3point? Going a 3 point is cheaper around here for sure. I have a drainage ditch in front of the place that is about 200 yards long that
will be the worst of it as far as angles go.
My tires ar R-4? and not filled. I use my backhoe for balance when needed. Main use of the tractor is work, digging and leveling. I'd like to get more use out of it, but, I don't want the yard all rutted either.
   / TC-30 belly mover
OK, you guys did say 3 pt :). Need to put those glasses on!
   / TC-30 belly mover #7
The only reason I have ever thought a rear mower would be considered was that putting a mid mower would be more expensive - what don't you like about the mid mower that makes the rear mower your preference? I have read about people using them to get under shrubs easier, I get that, but I had a front mower and didn't like it much. It was very heavy and would not always go where I wanted it as easily as a mid mower. Obviously this is a presence thing, just never heard someone call a mmm big and heavy and wondered what your reasoning is.
   / TC-30 belly mover #8
5 acres mowing with a TC-30 would be a good fit.
As far as a midmount mower...does your tractor have a mid-PTO? If not, a midmount is a moot point. They're also rather expensive.
Your TC-30 can handle a 60" or 72" rear finishing mower with no problem. That's what I suggest you purchase...(you determine the width based upon how much money you want to spend...RFM's aren't cheap either...just cheaper then a mid mount mower).
   / TC-30 belly mover
Actually it's the tractor Im wondering if it's too big and heavy for this use. Field mowing I don't think I'd care if it rutted the ground but the 5 acres I'm talking about is presently groomed and I'd like to keep it that way without killing myself trying. The sellers had a service come in to take care of things on the property and my goal in the long run is to keep it at this level then reclaim even more as I get use to the amount of work involved.
I've never cared to pay someone to do something I can do myself.... :) Besides, it can be a great excuse to buy a new toy, tool I mean.
   / TC-30 belly mover
Yup, mid mount pto is present. Only mowers I'd say I'm knowledgeable about are the walk behinds. Know nothing of the others, yet.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2016 FREIGHTLINER...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
JOHN DEERE 24" PIN ON EXCAVATOR BUCKET (A52707)
JOHN DEERE 24" PIN...
