Are auger bits interchangeable?
   / Are auger bits interchangeable? #1
Rail Dawg
I have a Rhino L200 auger that came with a 9" bit.
I also need a 6" bit... are most bits these days standard or do I have to go with a Rhino?
Thanks.
   / Are auger bits interchangeable? #2
I would measure the diameter of the auger pipe and the bolt holes just to be sure. You could
always make an adapter with a short piece of pipe to connect the new 6' bit to your auger head.
   / Are auger bits interchangeable? #3
They are universal to a degree, some offer round in two different diameters as well as a hex shaft! There is different flighting available as well as different cutting tips depending on your conditions and they do very in pricing depending on the way they are built.
With knowledge of the diameter and the desired flighting you could go to any dealer to get one.
   / Are auger bits interchangeable? #4
Good answer:thumbsup:
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2000  INTERNATIONAL 3800 MID SIZE SCHOOL BUS (A54607)
2000...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
CASE TR310 SKID STEER (A52705)
CASE TR310 SKID...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
