Are auger bits interchangeable?
/ Are auger bits interchangeable? #1
Rail Dawg
I have a Rhino L200 auger that came with a 9" bit.
I also need a 6" bit... are most bits these days standard or do I have to go with a Rhino?
Thanks.
/ Are auger bits interchangeable? #2
I would measure the diameter of the auger pipe and the bolt holes just to be sure. You could
always make an adapter with a short piece of pipe to connect the new 6' bit to your auger head.
/ Are auger bits interchangeable? #3
They are universal to a degree, some offer round in two different diameters as well as a hex shaft! There is different flighting available as well as different cutting tips depending on your conditions and they do very in pricing depending on the way they are built.
With knowledge of the diameter and the desired flighting you could go to any dealer to get one.
/ Are auger bits interchangeable? #4
Good answer:thumbsup:
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
