L3240 vs. L4400
   / L3240 vs. L4400 #1
Cwc131df
Looking for opinions on the L3240 vs. the L4400. I have 160 acres hunting land and need a tractor. Using it for food plots, maintaining trails, box blade for driveway, loader and grapple for brus and minor dirt work.
I have looked at both tractors and can't decide which way to go.
Thanks
   / L3240 vs. L4400 #2
Thanks
L4400 would allow you to use a bigger mower because of the HP both are great tractors the 3240 is a Grand L tractor with more features and the L4400 is a simpler tractor without all of the electronics and such.
   / L3240 vs. L4400 #3
Have you compared the features you gain with the 3240 compared to the 4400? Are you comparing these two models because of a budget and their priced similar? Do you feel the features on the 3240 are worth the hp your giving up to the 4400?
Personally, if its a tractor your only going to use once or twice a month then go with the L4400. The extra hp will help you get the jobs done faster. Now if its a tractor your going to be using multiple times a week or even once a week then the added features on the 3240 may be worth while.
   / L3240 vs. L4400 #4
The loader is a little better on the L3240.
   / L3240 vs. L4400 #6
Your brief description of what you will use it for doesn't tip the scale in favor of either unit... they both should have your work requirements covered pretty well. The L4400 has quite a bit more hp, an advantage if you were doing lots of pto work such as brush mowing. The L3240 has more features and is a really nice package. It boils down to your preference. Can't lose either way.
   / L3240 vs. L4400 #7
The L-4400 would certainly work circles around the 3240 because of the horsepower and would be a better buy for putting into the woods situation.
   / L3240 vs. L4400 #8
The L514 is not a better loader than the L703 that is on the L4400 IMO.
But if you step up to the L724 loader (and I think you have to jump to the L3540 to get it) then THAT is a better loader than then L4400.
But in order to answer the question, we need to know what you are going to do with the tractor? If you plan on using the PTO a lot (like mowing, chipper, tiller, bushhog, etc) then the added power of the L4400 would me MUCH better IMO.
If it is all ground work, pulling logs, etc, then they both weigh similar and you arent going to notice much difference.
If you plan on using the loader a lot, and like the features of the GrandL, then My best advice is to look at a L3540 or L3940 with the LA723 loader:thumbsup:
   / L3240 vs. L4400 #9
You can get the LA724 loader on the 3240 which will compete with the loader on the L4400, but it is not a fair comparison because of the hp. If HP is what you are after then get he 4400. If the machine itself is a big deal go for the GL:thumbsup:
   / L3240 vs. L4400 #10
Or just jump to the 4240/4540 if he likes the features if the GL but wants the HP of the L4400.:thumbsup: But ofcourse that will add a few bills$$$ to the pricetag.
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
100 FUEL TANK (A53843)
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2013 John Deere 824K Wheel Loader (A53473)
2013 John Deere...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
