Front-End Loader Rock & debris bucket
   / Rock & debris bucket #1
KYDan
Frankfort, KY
Kubota MX5100 HST 4WD
I have been looking for a rock and debris bucket for my MX5100 and found this manufacturer doing a search, Hayspear.com. Here is a link to the bucket.Rock rake and bucket has removable ends is 84" long
I need a 72" bucket and they can make one for less than the 84" shown on the website link.
I am hoping to find someone that has had some experience with this company and can advise me about the quality and functionality of their products.
As a followup to my prior message my plan is to use this as a poor man's rock picker. I intend to rake the area first with a Bush Hog scraper scarifier with just the scarifies extended to rip the area and then followup with the rock bucket/rake to pick up the rocks. Can anyone provide me with some thoughts of the plan and why it may not work? Also, I am clearing some brush areas and I thought the bucket would be ideal for that project.
I am attempting to keep this thread alive hoping that someone on the list may have some experience with this. I also have another question somewhat related that someone may be able to address. I am looking at some Bush Hog brand scraper scarifier boxes. The 2 boxes that I am primarily interested in are the retractable blade box RBX 780 and the rollover box model # RO 720. Any information regarding these would be helpful.
   / Rock & debris bucket #4
Don't know about this company but I do have a rock bucket for my 110tlb, it is 66" wide and is quite a load. Don't think I would want it to be much larger as you need to shake them to drop the dirt, I suspect a heavier wider model would be abusive to the fel.
Thanks for the response, I have the LA 844 loader on my MX5100 and the lift capacity at 500mm forward which is the actual lift capacity is 1852 lbs. I have the 72" HD bucket which is a lot heavier than the standard and it lifts a full load of rock, dirt, etc. without any issues. Since I plan to use this a rock picker of sorts after I have ripped the area I can test it at any point in the process for capacity. If I pick up the load and it appears "squirrelly" I can always dump part of the load. I am leaning towards Washburn bucket, but I am waiting until after the farm show to see everything else that is available.
Thanks again for the response.
   / Rock & debris bucket #6
If your loader is rated for 1850 lbs then a 66" rock bucket would be about right. The issue is more about the stress while shaking the dirt out of the bucket.
   / Rock & debris bucket #7
Just a thought? I have a Kubota L4400 with a LA703A loader. The bucket is 72 inches. I installed a tooth bar made by W.R.Long which has 8 teeth. This set up enables me to dig under the rocks and the tooth bar also helps in pushing and lifting the rocks into the bucket. This set up may not be suitable for your intentions, but it works for me. Just trying to help.
I omitted in my posts that these are custom buckets and I priced and probably will purchase a 72" one. They will build it to work with the Kubota QA system.
Thanks, I already have 2 of the toolbars from Iowa Farm Machinery Sales. And, they work great for digging and working for me. I use the standard one for digging and the flat one for leveling. I am extending my runway and the flat one works great for that, but is not stout enough for general work. I plan to use the rock bucket for a rock picker and for brush removal where I am running new fence. It has removable end panels that will allow the limbs to extend past the ends of the bucket. I am going to the National Farm Machinery Show first to see what else is available and hopefully get some prices. I sent a message to Bush Hog about their box scraper series to see if they will have any of them displayed at the show. I am leaning towards the extendable scarifier 78" model as it is close to 900 lbs. and I plan to use it to rip areas and then use the rock bucket to pick out the rocks. I have been rock picking by hand for years. We have Eden Shale soil here and it seems to grow rocks!
   / Rock & debris bucket #10
Dan,
What is the smallest rock size you want to pick?
Mine has 3" spacings and that leaves alot of rocks. Works well enough to remove the larger ones but small rocks will fall through. I have considered getting a power rake to use with mine for the small stuff but don't have enough use for one yet.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2016 Nissan Frontier Ext. Cab Pickup Truck (A53422)
2016 Nissan...
Small Trailer frame (A53117)
Small Trailer...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
