Meyers plow to quick attach FEL
   / Meyers plow to quick attach FEL #1
bharrisii
Mahindra 3215
I tried searching for the answer to my question but haven't found an easy DYI solution.
My goal is to find an adapter or a relativity easy build to attach a Meyers plow to my Mahindra 3215 quick attach FEL. I got the plow for free and would like to attach it for hopefully low cost.
Any help would be greatly appreciated!
Image attached.
   / Meyers plow to quick attach FEL #2
Use the search function to provide many plow builds like you are planning. Key words are FEL Plow, Snow Plow, Meyer Plow.
I recently had an adaptor made at a welding shop to attach my Meyer plow to my JD loader. You will not find a ready-made "bracket" like you are looking for.....but getting something fabricated is not too difficult if you have the skills or know of a good welding shop.
Good luck.
   / Meyers plow to quick attach FEL #3
These guys make one, you could get an inexpensive quick attach plate on ebay and use this one as inspiration to build your own.
Berlon: Snow Mount
   / Meyers plow to quick attach FEL #4
Are you talking skid steer style quick attach? If so, it is a fairly easy build. SSQA plate to start with, and then weld on two sets of ears for the a-frame to pin on, and a bracket at the top center to attach the chain to. I have done two like this for skid steer plows, and they work great.
Thanks for the quick replies. As much as I would love to have a finished product, I am trying to do this on the cheap. Looking at the building off the SSQA plate idea.
Thanks again!
   / Meyers plow to quick attach FEL #7
this is how i attach my meyers. ray
   / Meyers plow to quick attach FEL #8
Hi bharrisii - I have been looking to do something similar with my non-FEL tractor, where I would use a truck plow, one with the electric motor mounted to the pump right on the plow assembly. Then I could use the electric remote at the cab, no need for hydraulics, especially since the ol' Massey has none! I hope you can share your project (include photos!) as it comes together for you... and welcome to TBN!!
Graham
   / Meyers plow to quick attach FEL #9
Image attached.
A comment on the small Meyers- check those angle irons where the plow trips. I just junked a 6' Meyers that I've had for about 5 or 6 years. Replaced it with a 7' Fisher. attached are pix of the set up I made. Note the messed up attachment to the frame. The attachment point was on the front of the frame and I relocated to the bottom. that shortened the overall length and also served to give a flat angle so that when you angle, you maintain contact for the full length of the blade.
There have been many posts on this subject so do a search
   / Meyers plow to quick attach FEL #10
Just a thought. I have a QA on my loader. Some years ago I bought a quick attach Bobcat style plate, and welded a cheap 3pt quick attach to it. Now having a 3pt adapter I have used it with a york rake on the loader, to get trash out of gullies. I have also used it with a carryall as a man lift, and a pole boom for setting trusses.
Although I haven't gotten around to it I thought of hooking a snowplow up the same way with a chain (for float) to what would be the top link. I think the snowplow brackets were about the correct width.
I don't have a photo. I hope my explanation was clear enough.:2cents:
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
