Metal Roof Question
   / Metal Roof Question #51
12/12 is a slope of 45 degrees above horizontal. I believe your weight will be on your harness 100% of the time.
Especially on a slippery metal roof. I wouldnt do the job without someone to belay me from the ground and a fixed line that would catch me before I hit the ground.
Might almost be easier to get a manlift, tilt the bucket forward so that you are "laying on the front rails" and the front of the bucket matched the roof pitch, drop in a piece of plywood to lay on and work from there.
Aaron Z
   / Metal Roof Question #52
On a clean dry roof with gum soled shoes at times you may have none of your weight on the rope, been there - done that. But still use the rope for the rest of the time. MikeD74T
   / Metal Roof Question #53
12/12 roof slope:
   / Metal Roof Question #55
I've got 7/12 steel on my shop that I put on myself. With washed clean soft rubber soles right after a rain, you can JUST hold your position on the roof if you don't move. Any other conditions you are always between slowly sliding and quickly sliding.
My sisters barn was sided with steel in the 1950's. We pick up all the nails every year and go over it with screws. The first screws I put into it were 20 years ago, haven't moved.
To the guy who wants hand torqued, you're nuts. I've used drills but the torque limiter think doesn't work well. Cordless impact by far is a better tool for reliable compression of the washer.
We have snow here, I installed everything on the top of the rib. It leaks less when sitting in snow, it gives the screws some room to lean as the 36 foot long panels grow and shrink with temp changes.
On the flip side, you have to be really careful not to overdrive and cause the panels to get out of square. You can steer a roof about 1/4" per 36" sheet without meaning too if you're not careful. Top of rib does make stripping unlikely to as it will kink the rib first.
Re green purlins, you have to use short screws in green wood. Or they will loosen as it dries. Same as drywall, long screws = more nail pops.
   / Metal Roof Question #56
I had a metal roof installed a few years back, one part on a very steep pitch. The roofers threw a rope over the top of the roof and tied it off to the fence (or your tractor). Another rope went over and was tied off to a ladder that lies on your roof. Use a second ladder to get on the roof and on to the one lying on the rood that is tied off. The other rope you use to hold on to. They climbed up the ladder lying on the roof without any problems whatsoever.
This seemed simple and safe and you could easily do this job yourself and replace the screws remembering not to overtighten the screws with the rubber gromets.
Fred
   / Metal Roof Question #57
Since we have a great roofing discusion going has anyone used
metal shingles.
My aframe (about 20 sq) needs to be reroofed, in some areas, and I would like to get a metal roof. I cant afford a standing seam metal roof now, and I feel the panels would be too heavy for me to get done safely. I can see using stone coated metal shingles. The fastners are hiddden, and the instillation looks like something I can do. I can get a manlife in, and I have ropes and harness, and rock climbing shoes.
If i go with the metal shingle roof i will tear all the shingles off and put new tarpaper and ice and water dam down. I have seen batton/no batton on the install instructions, and also wondering if anyone has used battons on this type of install.
Metal Shingles | Metal Slate Roofing | Best Buy Metals
has the metro shingles.
   / Metal Roof Question #58
Just don't sit down :eek:
IMO you couldn't work comfortably enough using a rope to position yourself, you would need a hook ladder.
12/12 roof slope:
Now on that roof you could just lay the ladder on the roof, and you could still do that if the edge were higher, but if it is 2 stories the base of the ladder would be too far away.
JB
This is how we access difficult roofs. A steel hook ladder that you can attach sections to as needed. Called a chicken ladder, but I'm not sure why.
   / Metal Roof Question #59
Being a lifelong NH resident 12/12 is my favorite pitch. Snow don't stay long on a 12/12 metal roof. MikeD74T
Nor people :D
I also like steep roofs best :thumbsup:
   / Metal Roof Question #60
Seems like a fine way to do it :thumbsup: I'd make sure to wrap towels or something soft around the ladder so it doesn't scratch or ding/ dent the metal roof panels.
2012 International Derrick Digger (A55973)
2012 International...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
