Throttle for shuttle shift
   / Throttle for shuttle shift #21
I always use the foot throttle. I hardly ever use the hand throttle.
   / Throttle for shuttle shift #22
3R, you can probably deduce from my recent thread my motivation for doing this today: "I wonder if I can make my tractor HST-like and not make myself want a new one!"
LOL. Imagine my disappointment to realize I'm not a genius and am in fact just using it how it was meant to be used.
I grew up on tractors and still find I have a learning curve when going to a different type of tractor. As the hours pile up, you will find what works best for you.
As to not wanting a new tractor, good luck with that as for many of us it never ends.:laughing:
   / Throttle for shuttle shift #23
I see no problem to the engine using the foot throttle to change rpm.
I like the fact you can use your right foot to control the engine speed, let off it slows down. With the hand throttle you have to move it by hand to change rpm up or down. When using the loader I like to be able to have my right hand free for using the joystick. My right foot can take care of the throttle.
Now if I was doing something that required a steady engine rpm I would use the hand throttle. Loader work does not fall in this catagory.
   / Throttle for shuttle shift #24
Yep that's why the foot throttle is on gear tractors, When I had a gear tractor, I always used it a lot. Especially doing loader work or driving in the woods. Now when mowing of course just set the hand throttle and go.
But seriously, you still need to come on over to the "dark side" you know you want to.:laughing::laughing::laughing: I am just kidding, if your gear tractor is doing all that needs done, it is fine. Good luck and enjoy your tractor..
James K0UA
P.S. my offer to play with the HST still holds though.:thumbsup:
   / Throttle for shuttle shift #25
James K0UA
James, next time I visit my grandparents in Branson, I'm going to plan to pay you a visit. I'll give you plenty of notice so hopefully it'll work out. It's really generous of you to offer!
   / Throttle for shuttle shift #26
Unfortunately my next tractor will have to be a HST as my left knee is starting to give me a lot of problems (pain) and if I'm doing a bunch of loader work by the time I get off the tractor I can barely stand.
Also someone asked if reving up the engine to a higher speed and leaving it there to change between forward and reverse would be a problem. I believe it would be a matter of technique and tractor brand. On mine it's not a major problem as mine has a wet clutch. I my case depending on gear I might grind some if I try and change to fast.
   / Throttle for shuttle shift #27
On my JD 3320 with a reverser tranny, i clutch when using the reverser. Seems to be real smooth. Just a matter of clutch throw reverser lever and let out clutch, very quick and no jerking motion even at pto rpm.....
   / Throttle for shuttle shift #28
I do the same thing when mowing and need to make a tight turn. I slow down to an idle finish the turn and then speed back up to 2000 rpm. I'm fairly certain it's hard on fuel economy, but I don't think it will hurt a diesel engine.
   / Throttle for shuttle shift #29
Here's a related question that I can't find in search (iPhone again). Can I shift my crash box tranny on the fly? I know the manual says not to, but that doesn't make sense to me. Seems that if I match gear to RPM it should slide in nice and easy. Obviously I haven't tried this.
(I only mean forward gears, not forward-reverse)
What about high and low ranges? Can I shift those on the fly? Can HST tractors do it?
   / Throttle for shuttle shift #30
I wouldn't suggest "dry shifting" a crash box. But I've never tried it. Just shifting a manual tranny car without the clutch takes some good timing and a lot of familiarity with the vehicle. And the car has synchros, which I don't think the crash box has.
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
154 (A52708)
154 (A52708)
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
