AKwelder
- Joined
- Sep 24, 2008
- Messages
- 237
- Location
- Fairbanks Alaska
- Tractor
- Kubota B8200, 1953 International "Super C"
if you want a simple system, try this, it works. I have installed several dozen of these.
1- Get a small efficient boiler, we use Monitor fuel oil fired units, but most of the boiler manufactures have small good units. You might look at the gold series by Burnham, they come in gas or fuel oil. The most practical thing is that it must be able to have VERY cold return temps. We refer to this as a condensing boiler.
2- Look at the TACO mixing block, this unit has both pumps and the controls already installed. But it will be a sticker shock until you check the price of each component.
3- install 1/2 inch PEX tubing loops in the floor, if you have a single room in shop you don't need any Zones. The mixing block will do the job with a single thermostat.
4- When you install the manifolds make the first loop branching off the system the last loop in. This looks opposite from what i said. this means that the supply and return attach to opposite side of the manifold when the loops are paired together. This will balance the pump and flow through the floor
We heat small shops here in Alaska and only burn 200 gallons a year, for way up here it is very impressive.
As for an ice melt system, just leave a extra loop, later you can hook it up, in extreme cold we have to use another pump to flow the Glycol.
You can find most of the information at the site heatinghelp.com
