Best Glue for Metal to Glass?
   / Best Glue for Metal to Glass? #1
Travelover
Elite Member
Washington
B7100
I have a sliding window in my camper and I broke loose the aluminum handle that lets you slide the glass back and forth. The old glue was black and rubbery when I sliced it off the glass.
Anybody have a recommendation for a strong metal to glass glue? There is a 1/32" or so gap between the bracket slot and the glass so I'm thinking that a rear view mirror glue would not fill the gap. :confused:
   / Best Glue for Metal to Glass? #2
Why use a spacer to fill the gap. Then mirror glue should work or there is an instant glue that is suppose to glue most everything.
   / Best Glue for Metal to Glass? #3
black P/U windshield glue / sealer.
sold in caulk tubes at napa and carquest, etc...
   / Best Glue for Metal to Glass? #4
LOCTITE Stick'n Seal ORIGINAL Waterproof Adhesive.
   / Best Glue for Metal to Glass? #5
it sounds like the "glue" you cut out was silicone. Do not use a urathane or butyl . The big box stores do not sell com/industrial silicones ( GE 999) . you might try a 3m double face tape/or glue that is UV (blacklight) activated . Try a local comercial glass shop, for the ammount of silicone you need they might just do it for next to nuthin..?
AK9
it sounds like the "glue" you cut out was silicone. Do not use a urethane or butyl . The big box stores do not sell com/industrial silicones ( GE 999) . you might try a 3m double face tape/or glue that is UV (blacklight) activated . Try a local commercial glass shop, for the amount of silicone you need they might just do it for next to nuthin..?
AK9
I actually think the original adhesive was urethane. It was black and rubbery when I sliced it off the glass with a razor blade.
Good idea on the glass shop.
   / Best Glue for Metal to Glass? #7
I have built aquariums using Lexel adhesive. It can hold more than the glass it is attached to. It comes in a tube at most hardware stores.
   / Best Glue for Metal to Glass? #8
it sounds like the "glue" you cut out was silicone. Do not use a urathane or butyl . AK9
why not use a urethane?
it's what seals yer windshield..... and sounds exactly like what was removed...
soundguy
   / Best Glue for Metal to Glass? #9
I agree this stuff will stick to about anything if it is clean and will provide a good seal. It has the smell of model air plan glue I remember from child hood. Not that I sniffed it or anything:confused2:
   / Best Glue for Metal to Glass? #10
If it is a small handle, thoroughly remove the old adhesive, and use a rear view mirror adhesive kit, from an auto parts store.
That will give you the strongest bond.
17101 (A55787)
17101 (A55787)
UNUSED 1RGC40 MINI GOLF CART (A57193)
UNUSED 1RGC40 MINI...
1544 (A57192)
1544 (A57192)
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2024 CRATOS TWINCA ES500 ELECTRIC DUMPER (A57192)
2024 CRATOS TWINCA...
2013 Ford Taurus AWD Sedan (A55853)
2013 Ford Taurus...
