check your lug nuts + torque wrench madness
   / check your lug nuts + torque wrench madness #41
Unless the lugs/studs we're talking about are made of butter, the amount of heat they're exposed to will absolutely not result in any stretching.
I don't know much about exactly how much stretch a particular fastener might have at a particular temp increase, but I do know that everything in the known universe is elastic to some degree.
In fact if bolts didn't stretch the whole concept of putting a torque wrench to them would be useless. As soon as the nut bottomed out it wouldn't turn any more. Applying additional torque is for the purpose of using a defined amount of stretch to provide additional clamping force to the items being bolted together. In some cases the required torque is such that the bolts are stretched beyond their yield tolerance, such that they become permanently stretched and should not be reused if they are ever removed.
Most of that engineering stuff is over my head, but I am aware of it. Saying that a bolt absolutely won't stretch with a little heat, while subject to some stretching force, cannot be accurate. Maybe in this application it wouldn't be enough to matter; I can't argue that. But it is possible they could stretch.
   / check your lug nuts + torque wrench madness #42
In many applications as I am sure most of you are aware bolting gets replaced after so many uses or even after one use (torquing). In some large bolting applications I have seen the studs are hollow and an electric heater is inserted into the stud to raise the stud temperature to what will be the operating temperature when in service. Then the studs are tensioned (not torqued) until they stretch an engineered distance; the nut is then run down the thread by hand and hand tightened then given a light snugging with a wrench (again by hand) and then the tension is released from the stud. This was on 6" diameter studs on a pressure vessel with an operating pressure over 600 PSIG.
As was said every time a fastener is tightened it is stretched slightly and it never returns back to its original dimensions. Eventually it will be come so elongated it can not met design specs and must be replaced.
   / check your lug nuts + torque wrench madness #43
Commonly known as 'worn out'. :D
   / check your lug nuts + torque wrench madness #44
I put about 150 miles on a new trailer, and remembered to check the lugs last night. At least one lug on each of the four wheels took an honest half turn before tripping the torque wrench at 95 ft-lb. The rest were OK.
Oddly, my torque wrench stopped working about halfway through the job. Couldn't figure out why this would happen, since it was working fine last time I put it away.
Well, I took the ratchet head apart, examined everything to figure out how it worked, and found the problem -- whatever grease had been in there was all gummed up and had turned into varnish. This was preventing the ratchet mechanism from working, and it was stuck in a free wheeling position. I cleaned everything out, put new grease in, and went back to work.
And that's how a simple one-minute check of 20 lug nuts turns into a messy 30-minute job. Story of my life. I don't know what kind of lubricant Craftsman put in that ratchet mechanism, but it sure gummed up pretty bad. The wrench is about 14 years old.
After disassembly, you should have it calibrated, or at least verify it against another torque wrench (that you know is good).
Calibration is preferable, but if not possible, use the other (known good)torque wrench and torque a fastener to a given torque. Then set your reassembled wrench to that same torque and see if the fastener moves. Better to set torques two or three settings in the wrench's range and ensure it's working correctly throughout the range. Again, not the best way...but it works.
This actually works better with deflecting beam or dial indicator torque wrenches, IMHO.
   / check your lug nuts + torque wrench madness #45
I still don't understand why all the panic about the wrench calibration after having the ratchet apart. The ratchet mechanism is entirely separate from the torque sensing mechanism. He could have welded the ratchet mechanism solid and it would still sense torque as good or as bad as it did before.
   / check your lug nuts + torque wrench madness #46
Just good sense, Bro...check the accuracy of your tools, especially after any kind of disassembly.
   / check your lug nuts + torque wrench madness #47
Cause I hate having to tear stuff apart to get at a broken bolt and try to extract it... Cause it is always in the absolute worst spot for access etc.
   / check your lug nuts + torque wrench madness #48
Old grease can gum up like that. I have seen it in $10,000, $20,000+ microscopes. Nikon, Leica, Olympus... The greases just dry and harden over time. A few years back, a group at work was ready to scrap a really expensive microscope. It was a few years old, but was still an excellent microscope. I had my microscope service guy do an annual on it for $200; scope worked great. He had to scrape the dried lube off some parts.
   / check your lug nuts + torque wrench madness #49
......:thumbsup:
.......:confused2:
........:confused2:
   / check your lug nuts + torque wrench madness #50
You miss my point. The wrench either is within calibration spec or it isn't. Disassembling the ratchet doesn't affect calibration in the least.
   / check your lug nuts + torque wrench madness #51
For all the bluster and posturing, some basic understanding of how the tool actually works might benefit some of the participants here.
   / check your lug nuts + torque wrench madness #52
......:thumbsup:
.......:confused2:
........:confused2:
As a guy who claims to be an engineer, I'm quite surprised by your post...
   / check your lug nuts + torque wrench madness #53
Do you know that, or think that?
Personally, that would be a poor practice to me (and unacceptable at most, if not all companies I've worked at) and I think you're providing bad advice to the guys on TBN. As a former NH service tech, you never torqued fasteners?
However, you do what you want to do with your wrench.
Having done the work myself, and being a mechanical engineer, I believe that the work done on the ratchet mechanism is independent of the torque performance and calibration of the wrench. The wrench could certainly benefit from a periodic calibration, but not because of the work done on the ratchet head. All the ratchet parts sit within a collar that attaches to the rest of the wrench, and simply transmit the applied torque to the socket. It either works, or doesn't. Whatever effect it has on the applied torque is either going to be to transmit it 100%, or not transmit it at all.
   / check your lug nuts + torque wrench madness #55
Thank you.
   / check your lug nuts + torque wrench madness #56
When I bought my Snap On torque wrench a couple of months ago, I specifically asked about this topic, because the ratchet mechanism has a different warranty than the rest of the wrench. I was told by my Snap On dealer, after he has gone through training on the subject that the ratchet mechanism has nothing to do with the torque sensing mechanism. The ratchet heads are designed to be field serviceable without compromising accuracy or affecting the torque sensing portion of the wrench in any way. That's why if there's a problem with the torque sensing portion of the wrench, it is required to go back to Snap On corporate, while a broken ratchet mechanism is to be fixed by the dealer in the field.
   / check your lug nuts + torque wrench madness #57
I didn't say that it would be "good practice" to weld the ratchet of a torque wrench, I said doing so would not affect the torque sensing mechanism.
If I'm providing bad advise to TBN faithful I have lots of company. Having letters after one's name doesn't guarantee an endless supply of common sense any more than a lack of a professional degree is a certain indication of stupidity.
I don't know how you got the idea that I don't torque fasteners or know how a torque wrench works, but you need to shift down a couple of gears and think about the information contained in this thread.
   / check your lug nuts + torque wrench madness #58
I understand the interactions of various functions in a torque wrench enuf to establish their interdependence, or lack thereof. Pehaps this has something to do with being an engineer, but I attribute it more to observation of how things work. I am, however sincerely concerned that there might exist engineers of mechanical persuasion that are not able to see how, or not, one thing affects another in a torque wrench.
...larry
   / check your lug nuts + torque wrench madness #59
There's a torsion bar or spring and a pawl inside. The fit and alignment of that pawl is what's critical. When apart, the pawl should be measured for wear.
Most torque wrenches (and measuring equipment in general) are cleaned and verified during calibration. This equipment isn't normally disassembled unless there's a error in the tool.
At this point, you're using a device with unknown accuracy. That's a risk...just depends if you can live with that risk.
BTW, I'm a Quality Engineer. Calibration is not the primary focus of what I do, but it has been in that past. I get my torque wrench calibrated every two years (but I'm fortunate enough to have a friend who owns a calibration lab so I get it done at no cost). Two years works for me since I really don't use it very often anymore....just wheel bolts/nuts.
   / check your lug nuts + torque wrench madness #60
The ratchet head of just about any commercially available ratcheting torque wrench is separate and distinct from the torque sensing apparatus. I can't imagine why it is so difficult for you to grasp this fact and accept it.
Enjoy the rest of your day.
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2005 INTERNATIONAL 4300 SBA 4X2 FLATBED DUMP TRUC (A60430)
2005 INTERNATIONAL...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
