TC25d v TC40D
   / TC25d v TC40D #1
BigFoot032257
Greenfield , PA
TC25D 2002
Are theses two tractors (Tc25d. Tc40d ) 2002 on the same frame if so are the tires the same size ? And whats the wt dif
   / TC25d v TC40D #4
No and No. The weight difference is dependent on wheel & tire equipment and any added ballast. Average shipping weight for the TC25 is 2206 lb. I can't find that figure for a TC40, but I'd put it at about 2650 or so. Differences in liquid ballast capacities would broaden the spread.
I don't use Tractordata.com as it has too many inaccuracies for my taste.
   / TC25d v TC40D #5
Would you please enlighten me in regards to what source you utilize that is more accurate? The website that I mentioned is what I have used for past references. I would truly appreciate the assistance. Thanks.
   / TC25d v TC40D #6
Nebraska tractor test results where applicable.
Manufacturer's data.
Data published in Intertec I&T repair manuals.
Some of Tractordata's info is accurate, some is garbage. As with anything, the trick is to sort out the grain from the chaff.
   / TC25d v TC40D
Thanks I thought the two had the same frame so the puckits of one could go on the other as with the tires too R4 ! :thumbsup:
   / TC25d v TC40D #10
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
FAE 150/540 LOT NUMBER 137 (A53084)
FAE 150/540 LOT...
LOT NUMBER 250 (A53084)
LOT NUMBER 250...
1992 GROVE CRANE (A52576)
1992 GROVE CRANE...
