Box Scraper What to look for in a BB scraper
   / What to look for in a BB scraper #1
eagleeyetv
Trinity, North Carolina
JD 2320
I'm looking to purchase a BB scraper. What do I need to avoid and what go I need to look for in a BB?
   / What to look for in a BB scraper #2
If for your JD2320, the two most important considerations are tractor horsepower and tractor wheel width. 24 engine horsepower is a given, but we don't know what tires it's wearing. What is the outside width of the tire track, both front and rear?
//greg//
Yes it's for my 2320 which has R-3 tires, loaded on the back. It has a width of 51 inches, so I'm thinking 54 or 60 inches for the BB. I'm currently looking at a Woods BSS54 2010 model that is heavier duty then their current model.
   / What to look for in a BB scraper #4
60 inchers are far far more common, so I think the 54-inch search may end up expensive. Unless you trip over a used 54 that is, so don't rule it completely out. Now by the time 24 hp gets reduced down to drawbar hp, the number is pretty small (something less than 17). Plus R3 tires are designed for floatation, not traction.
So you don't need anything very heavy - or very aggressive. A 24hp hydro on R3s ain't gonna beat up a box too bad, so you're not looking for thicker than usual steel. But one thing I always look for is strength in the boxblade A-frame. This is especially important if you use the thing in reverse to push stuff around. Simple flat steel - like in this photo - represents the weakest design. I prefer to go for something with a little resiliency, like this. After that, it's pretty much a matter of how much money you're willing to spend.
//greg//
My local dealer has the 2010 model for sale for $750. Kind of pricey, but I looked at it yesterday and its beefy. Thicker metal all around and it weighs almost 600 Lbs. I has 4 teeth, and I know that if I went up to 60, I would get 5 teeth. The box sides look like it's 3/8 steel, so I'm sure that it is stronger then most. I just think that it might be too much for my yard project.
   / What to look for in a BB scraper #6
Look at the Bush Hog SBX60. I have the 72" version. It was the best $500 I ever spent.
   / What to look for in a BB scraper #7
I just think that it might be too mush for my yard project.
yeah, sounds like a little too much boxblade. Here's a 382 pound 54-incher with a decent A-frame, for $730 delivered. The seller is a respected advertiser here. If you have a KK dealer within driving distance, you can probably pick it up yourself for around $600. The make/model is King Kutter BB-G-54
//greg//
   / What to look for in a BB scraper #9
The photo greg g posted in a link has a feature you should look for. That is, a clevis-style type of hook-up. Some of the other photos don't have it.
Here is what it looks like. Don't mind the extra junk on the pin in the photo. Just look at how it is constructed. Much stronger.
   / What to look for in a BB scraper #10
20702 (A51694)
20702 (A51694)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55218)
Ditch Witch 6510A...
100 FUEL TANK (A53843)
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
