72 inch Rachet Rake on sale at TSC $199
   / 72 inch Rachet Rake on sale at TSC $199 #301
But Ratchet Rake won't sell it to me for $199! :(
Bruce
TSC is closing out the 72" below their cost because they found their market consists primarily of the smaller tractors/buckets, according to what the RR folks told me.
   / 72 inch Rachet Rake on sale at TSC $199 #302
Are any bottom brackets supporting the ratchet rake under the bucket?
I have a 54" bucket and hook mine up using the brackets under the bucket with the two center brackets on top...
Has worked well and do not foresee any problems...
   / 72 inch Rachet Rake on sale at TSC $199 #303
Yeah, the ones on the ends are identical to the ones in the center.
   / 72 inch Rachet Rake on sale at TSC $199 #304
Has anyone tried it- with bucket in float position- on ice?
A few years back we 3" of solid ice for weeks. I wonder if those teeth would tear it up.
Tried mine on ice not too long ago..... Didn't work too well for me!!! Although it did put some nice grooves in it for better traction.
   / 72 inch Rachet Rake on sale at TSC $199 #305
Looks like you guys talked this ratchet rake thing up too good. Called area TSC the other day, they don't have a single one left - of any size. I said "in the store?". She said "No, in the warehouse".
//greg//
//greg//
Man did I mess up, I should have negotiated with rachet rake on a commision before I started this thread back on Jan 3rd.
I should have known that all TBN users have at least 2 things in common , love for tractors and love for a bargin on an attachment for a tractor !
Seriously, glad it has worked so well for so many. It has been so wet I have never even used mine for what it was intended.
   / 72 inch Rachet Rake on sale at TSC $199 #307
Well thanks again! :thumbsup:
I've used the RR in conjunction with my scarifiers to dig out quite a few LARGE potholes for re-compaction when redoing gravel driveways. It paid for itself in the amount of time it saved me in only a few hours on the first couple of jobs. I've used it on ten or twelve driveways so far and I always have it along now "just in case."
   / 72 inch Rachet Rake on sale at TSC $199 #308
Tried out the RR today. It does pretty good. I have a Bobcat CT230 with a 60" bucket. The 72" rake fits right close to the edge of the bucket. One tab outside and the other tab wad inside the bucket.
It does better on loosed stuff and not so good on making new contour. It does not replace the box blade for this task. It does really good on stuff that allows the rake to sit with even pressure across the whole rake. Example would be in the woods I was clearing a trail and it was wide enough and all on the same grade so the rake was able to push all the leaves and sticks with no problem. As long as you want to go in one direction it works good, in order to keep pressure on the rake, it keeps the front wheels off the ground.
Here are some pictures showing the rake and some trails. There is one picture that shows the trail after two passes.
   / 72 inch Rachet Rake on sale at TSC $199 #309
Instead of the ratchet hook up can you mount it to the bucket permately? I'm not in love with ratchet binders, I've broke to many on my trucks binding loads . . .John
   / 72 inch Rachet Rake on sale at TSC $199 #310
The original prototype of the RR was a bolt on, as described and pictured on the website, so presumably it can.
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
