What size RFM for a JD2320
   / What size RFM for a JD2320
Yes, the suface rust is not bad at all. It is cosmetically ok, but I think just needs a tune up! Any idea where to get parts (the spacers and bushings for the wheel spindle). I also may need a new PTO shaft.
The guy didn't have a tractor. The mower has not been used "in a few years" he said. The blades turn, and nothing seems to be seized. I figured for $250, it was woth the risk.
I downloaded the manual already!!
Thanks.
   / What size RFM for a JD2320 #12
Thanks.
For $250, you can't go wrong...
You oughta check the gear box lube, the PTO driveshaft length (don't raise it until you know it's not going to bottom out!!!) and see how it runs.
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Ford N Series Tractor (A59814)
Ford N Series...
Skidsteer Wheel Tracks (A59814)
Skidsteer Wheel...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
