Environmentalist look away, Bubba figured out how to turn his truck up!
   / Environmentalist look away, Bubba figured out how to turn his truck up! #21
I have friends in Sao Paulo, Brazil. Apparently Formula-1 truck racing is popular... they have posted pictures on thier facebook a number of times.
[ame=http://www.youtube.com/watch?v=kG558hDacME&feature=related]Dirija com o piloto - Fórmula Truck São Paulo - meio do pelotão - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=QKZR9A8hhFo]Balé Volkswagen na Fórmula Truck - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=gDgKgsFdCJc]ACIDENTE FORMULA TRUCK 25/07/2010 SAO PAULO BANDEIRANTES INTERLAGOS CAMINHAO - YouTube[/ame]
I've watched those races a couple of times, those trucks are amazing! :thumbsup:
I have never seen that here in the States. Surprised... Would be cool!
That's because US motorsports suck, although Global Rallycross Championship is gaining ground! There's just something about a 550hp, 2400lb AWD streed car that I just can't get enough of!
Global RallyCross | 2012 Season
   / Environmentalist look away, Bubba figured out how to turn his truck up! #26
There is no such thing as detonation in diesels. Fuel is not injected until the piston reaches the ideal position, unlike gasoline engines, so there is no possibility of pre-ignition. Thats why diesels can run obscene amounts of boost with the only worry being: can the hardware handle the pressures. With a gasoline engine, too much boost causes detonation.
Look at top fuel dragsters running nitromethane maxing out at 60-65 psi of boost, whereas a pro-mod diesel pulling truck can run north of 150 psi of boost.
so you think a diesel engine cant pre ignite have you ever seen one somebody started on ether
   / Environmentalist look away, Bubba figured out how to turn his truck up! #27
   / Environmentalist look away, Bubba figured out how to turn his truck up! #28
That's not normal operation. Ether is like crack to a diesel, they become addicted and won't start without it.
   / Environmentalist look away, Bubba figured out how to turn his truck up! #30
The races where they are pulling trains are a little more dramatic...........
[ame=http://www.youtube.com/watch?v=dGXDJqrlOaM]Couture VS Coga - YouTube[/ame]
UNUSED JCT HYD AUGER 8", 12" & 16" BITS (A58376)
UNUSED JCT HYD...
Service Truck (A59230)
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
John Deere HPXD (A57149)
John Deere HPXD...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
