Planting 40ac.
/ Planting 40ac. #1
foreman Etexas
Elite Member
texas
Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
My question is should I disc or till?
I have a 6ft Tiller and a 6ft Disc,I do know I can run faster with disc but I can run pretty good with tiller also. Im planting tifton9 Bahia,I do also have a 12ft drag and roller,then a 3pt seeder and small 50lbs unit on my 4wheeler. I'll be running the 5040 and father-in-law has 40hp international will be using and hope some help shows up.
/ Planting 40ac. #2
Use the disc and chain the drag to the back of the disc. Use the other tractor to till new ground at the same time. You'll get the most done this way.
/ Planting 40ac. #4
I'd use the disc and drag and follow these instructions
Seeding Bahiagrass Pastures
I assume your seeders are broadcast type. Broadcasting and rolling will give probably 50-60% germination. A drop seeder/cultipacker unit like a Brillion would give better germination efficiency (~90%).
Good luck.
/ Planting 40ac. #5
I can't imagine tilling 40 acres. I think I would be looking at spraying existing vegetation and renting a no till seed drill.
MarkV
/ Planting 40ac. #6
MarkV
Good idea--spray, mow, seed with the no-till (assuming the OP can find a nearby rental place that has no-tills) :thumbsup:
/ Planting 40ac. #7
Here's what many do.
1st kill the vegetation by spraying it. Wait until everything dies. Some people do it a 2nd time in case any weed seeds try to sprout.
Hire out a BIG tractor and pull a heavy offset disc over it first. Pay attention to how well it digs in. I'm talking about a BIG disc that has 30" or bigger sized discs. If need be, have him go over it at a 90 degree angle the 2nd time at really hard packed areas.
Then get your disc out and smooth out the coarseness left by the offset.
Tilling is good, but if your soil is like mine, if I tilled mine, it would be so soft I couldn't drive a tractor on it for weeks, maybe 2 months, until it packed down enough.
/ Planting 40ac. #8
A couple things to ask yourself ... how long has it been since the ground has been renovated? How rough is this 40 acres?
It may be as simple as Mark stated, spray and no till ... if the ground needs work then think about subsoiling and discing and then seeding ... with weed control.
/ Planting 40ac. #9
I'm with the "plow then disc and cross disc" crowd. I personally would try to avoid having to use total grass killer unless it is a must, if for no reason than cost. Plowing the vegetation under should help loosen up the soil and put some free compost in the ground
/ Planting 40ac.
I have already mowed it, it doesnt have alot to spray(yellow flowers),and no-till rental isnt in the budget(waiting line is to long anyways). I do own a 21ft-300gal.sprayer but was going to spray at a later date when goatweeds start to grow(I sprayed last year)...
/ Planting 40ac.
Father-in-laws cant recall if it ever has been renovated,its kinda sandy loam,I did drag the pasture cple months ago its not rough at all can run 5/6mph no problem. The place does have some good hills to pull not flat at all. I have to have a prepared seed bed(NRCS paper work states).The drought has took its toll,plus the last renter over grazed it,so not really any grass ,just in places. If it was closer my neighbor were I live has a 21ft tandem but said it will be to wide to haul it,the 30+miles there and driving it on these small rodes with barely a shoulder wouldnt go so well,so thats were im at,using the smaller equipment. I have another neighbor that I helped get his 13ac.done,is bringing his tractor to help,so I have another 7'disc he can pull. So far we are going to have 3 tractors,6ft disc, 7ft disc and 6ft tiller(if needed). Just trying to get some ideas,on what would be the most plained out way to run this project. Also may have another friend with 4x4 workmaster55 with 6ft tiller,if his schuele allows him.
/ Planting 40ac. #12
I know from state to state things vary ... NRCS paperwork ... I assume you put it in the farm program for cost share? If so Atoka County Oklahoma office has a no till we can rent ... I think I'd ask the office if you can no till opposed to a prepared seed bed... they may also have one at your county office.
I have been told Bahia takes time to germinate and produce, with hills that you have ... prepared ground can wash away with rain and leave a real mess.
/ Planting 40ac.
I wonted to do no-till on the hills and told the rep that but when I got my paper work in the mail it states prepared seed bed. So I wont to do as the paper works states,I think I can do the one big hill in sections,going crossway on hill and use some square bales to keep wash to a minimium. I think no-till is a better route but the rental on one may be to high,cause im also building 2,000ft of fence at the same time. The grass seed has went from $140 a bag to $250 a bag so thats some extra cost,oh and most important taking the wife on vacation(without kids),we are going to witchita falls March 6-8 for farm show them probaly head up into Oklahoma and mess around,just going to take a drive...
Sorry didnt answer question.Yes cost shares program
/ Planting 40ac. #14
I AGREE with Kyle in Tex.
I live in s/w Missouri where the ground is hard and somewhat rocky.
Every year we would plant winter wheat for the cattle to graze. In early August
we would prepare the ground and plant the winter wheat. By late Sept. early October we would put the cows on it. Come spring we applied NITRATE to give the wheat a boost and when ready turn out the cattle.
The only way to break the ground in my area sufficiently is to use a big off set disk. You will need a large tractor to pull these disks at least 65- 70 H.P. but your results will be worth it.
And you won't have to spray the weeds before hand and that in it self is a great savings.
Remember, you need a firm seed bed before you plant your wheat. Now you can take this for what it is. But find the largest cedar tree you can and
drag it over your field, you will surprised how well this compacts the seed bed.
Use a fertilizer buggy with your seed and fertilizer mixed together and spread it. After you have done that get your ceder tree and drag it over the entire field again, believe me this works so very very well. no need for the roller or anything else . This method is time tested in my area and works.
Good luck , Duke
/ Planting 40ac. #15
Okay ... I've been in those programs and really ... talk with them, they are very open minded ... share your concerns and they will listen. I found in the past they can even come up with "emergency" funding if you whine about some of the cost going up since you made the application ... once I even stated "Well just cancel the contract cause I can't do my end" ... well all of a sudden there was emergency funding available to finish the job.... they need to spend the money so they can get the allotment for next year.
/ Planting 40ac. #16
Also ... if your coming to Oklahoma and you get in the area of Caney, Ok ... let me know !! We'll sit down and visit. If you think you may be in my area pm me and I'll shoot you my cell phone ... Well heck its on my website!!!
/ Planting 40ac.
Well I been thinking now since the Tifton9 has went to 250 a bag,should I be thinking about maybe another type of grass seed since the cost per acre is up anyways..
/ Planting 40ac. #18
We are from No Till country so I am a bit biased....but how is it possibly even close to be cheaper to make 3 passes across a field vs. renting a no till drill? Fuel, time, compaction from tractor, wear/maint...?
A proper no till application will be far superior to a "prepared seed bed" if the wind comes up or major precip comes your way.
Now if there isn't an implement available thats another situation entirely. Surely 40 acres can't take you very long to do with a no till right?
/ Planting 40ac.
Probaly wouldnt use a tank of fuel in each tractor,and the time is free. I spend every free minute helping others and when I finally ask for some help,I believe that others will show if able and own a tractor.I have been blessed to have what I do and will go an extra mile to help anyone in need. Im just going by my paper work,and no-till isnt an option but I will ask if I can but there just isnt alot of no-till rentals around here,I have a short window cause I have a full-time job,help take care of my parents ranch,take care of my own places,keep my boys when my wife is at college or work,help a guy feed his cows after i get off work,cause he has been going threw health problems,I help my neighbor work cows when needed,I help another neighbor since he didnt have a tractor but I sold him a tractor I had to help him get started for hardly nothing,I was helping coach little dribblers until they found a coach,im the type of guy that is going to pull over to lend a hand or be the guy you can call on(all for free).I dont drink,smoke,do drugs and my family is first.....................
Im just glad im not having to use a pulling MULE:D
/ Planting 40ac. #20
I would remind the NRCS boys what caused the Dust Bowl. Deep plowing and disturbing the topsoil in time of drought. Once you break the top crust of soil even on a loose soil moisture will be lost.
No-till would seem to be the route to take. I know you say it is not in the budget but one pass as opposed to several seems more cost saving.
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
