Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #211
Deerman 75: We want that 7018 to look like Shieldarc's sprayarc MIG weld he posted. If you get it like that we will allow you to put a tack weld on it to keep it from sliding off the plate. That is what a welder told me years ago describing his welding "so slick he had to tack weld it to keep it from sliding off the pipe"
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #212
Years ago, you could tell a good 7018 weld as the slag would peel up about 2-3" behind the arc and just fall off leaving a clean weld. I dont know what they did to the flux now as it rarely does that anymore except maybe a little bit on cap passes. Back 40 years ago, Atom Arc (now Esab owned)was the premier weld rod brand for iron powder electrodes and even a filler pass would peel up the flux and only require a light tap with a welding rod to dislodge it, now Lincoln and Atom Arc both need a power brush to get them clean.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #213
Problem was I found that even at 60 amps I was burning through 1" x .062 square tubing like I was using a cutter. (1/8" 6011 rod)
The 1/8 is too big, drop to a 3/32 rod and lower the amps more. 6011 is a high penetration rod also, you might try a low penetration rod like 6013 for the thin stuff. Switching the polarity to electrode negative also gives less penetration.
Ian
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #214
Anyone with suggestions on the reflections coming in from the back would really be helpful. I stopped early because I did not want to have an eye problem.
I think your helmet / hood is too big. I read your post earlier this morning, latter I went out to the shop and did a little welding. I have 48 lights in the ceiling of my shop, and I could not see one light in the back ground with this welding helmet / hood.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #215
It was not the reflections of the other lights it was the reflections of the arc itself that I am concerned about. Are there different sizes of hoods/helmets? My head is a 7 3/8 hat size which not large is certainly not small either.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #216
The arc must be reflecting off of something. I know if you see anything in your lens except the arc it can be very annoying!
I wear a 7 1/4 to 7 3/8 depending on the hat. This morning I really paid attention to any light, or anything inside my Pipelinner hood that could / should bother me, nothing! It fits real tight to the side of face, my head blocks all light from reflecting on the lenses.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #217
Annoying I can live with I am concerned about the safety to my eyes aspect.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #218
Not a pro welder, but I have some of the same reflection issues. Usually when I am too lazy to put on my leathers and weld in a white t-shirt. Also seen it when I weld near a white drywall wall. Just have to find what it is reflecting on and reposition or cover up the surface.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #220
The bike is pretty nice too.
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
Exmark Lazer Z (A50121)
Exmark Lazer Z...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
2021 Isuzu NRR Heil 9Yd Mini Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
7' x 7' Steel Frame Cover Hut (A50121)
7' x 7' Steel...
1998 Sherman +Reilly 6048 Single Drum Line Puller S/A Trailer (A50322)
1998 Sherman...
