JD 35 mini excavator won't start
   / JD 35 mini excavator won't start #1
gnwillson
Oklahoma
New Holland TC40DA - 8670 New Holland - Airman AX35 Mini Excavator
3 cyl Isuzu automatic bleeder on fuel system cranks smokes won't commence Ideas?
white like its not getting fuel
   / JD 35 mini excavator won't start #4
You are getting too much fuel for the amount of air you're getting. Greyish white smoke that lingers in the air is unburned fuel. White smoke that dissipates quickly indicates coolant or moisture in the combustion chamber. Check your air cleaner for restriction. Possibly you have a dribbling injector(s) that would cause over fueling. Check your fuel for water with water finding paste. How long have you had this symptom?
bought machine last fall had a bad cylinder on the boom. Had trouble getting it started then. It had a hydraulic leak so we only ran it long enough to load on trailer. It ran into my shop. Several days later got leak repaired. It ran that day. Waited all winter on hydraulic cylinder. Got that put on Sunday had to bleed air from fuel filters. Started right up. Yesterday would not start. Had to bleed filters again but could not get it to go. I knew this machine a couple of years before I bought it.
   / JD 35 mini excavator won't start #6
If it is necessary to constantly bleed the filters then you have an air leak between the fuel tank and the lift pump. Have you tried fresh fuel? Have you tried starting it without the air cleaner element in place?
It started. Can you flood a diesel engine? I am going to replace the fuel lines and the air filter. Thank You for the help.
   / JD 35 mini excavator won't start #8
Technically no, because there are no spark plugs, but you can get enough fuel into the combustion chamber to cause a hydraulic lock - which isn't good at all.
Glad you got it running. :thumbsup:
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A50322)
2007 Godwin Pumps...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Yamaha Vmax Boat Motor (A50121)
Yamaha Vmax Boat...
2014 Chevrolet Equinox 2LT SUV (A50324)
2014 Chevrolet...
