Trenchers?
/ Trenchers? #1
Tractor Beam
Is there any sort of 3 point or draw bar attachment for trenching. Simply cannot afford a back hoe. Not realistic! SO! Do they make any sort of trenching device or am I going to have to build one?
/ Trenchers?
Perhaps trencher is the incorrect word. I want to dig about 1000 feet of 18 inch deep trench just wide enough to lay a 2 inch pipe. Surely there is something like a plow, that can be draggedm ripping up that rock infested ground at my place! I'm about ready to build something I tell you!
/ Trenchers? #4
/ Trenchers? #5
What you might want to look for is a middle buster. Maybe run you 150-200.
/ Trenchers? #6
Trencher needs a hydro - I'm a gear fella, don't normally like a hydro in a tractor, but for a trencher you need a real slow slow gear - a hydro.
The middle buster might do it for you, might have to make a pass or 2 going a little deeper each time, and maybe drag the wire or pipe through on the last pass.
--->Paul
/ Trenchers? #7
I have to about 400 feet of trenches to dig for electric and water lines very soon
The Home Depot about 20 miles from me rents them for about $200 for a 24 hour period. It includes the trailer.
Most middle busters are limited to about 12 inch in depth...
/ Trenchers? #8
I rented a trencher last summer at American Rent All on I-45 between Rudy's and Splashtown on the Northbound feeder. Don't remember the exact rate but I think it was around $150/day. I used it and got it back in 4 hours and wound up paying either $105 or $115. They even furnished a small trailer to transport it at no additional cost. The thing looked pretty beat up and used but it ran and did the job for me. If you are trying to save money you might talk to them. With the other quotes I had, I figured it would pay for me to drive from Conroe and back. Good luck.
/ Trenchers?
I'm looking at rigging up a plow of some sort to my rear blade. I have time and I have steel, but not much money. I'll let you guys know whayt I come up with....:)
/ Trenchers? #10
JJ sent me a pic on one of the other areas of a subsoiler that is a 3 pt hitch affair. I believe they are at TSC. I don't have a TSC or much $$. I thought about extending one of the scarifiers on the box blade.
RC
/ Trenchers? #11
I rented a Ditch Witch 1330 trencher from Home Depot and cut 1100 ft of trench 18" to 30" deep 4" wide in about 8 hours. Cost: $125/day. Rent it on a Saturday and get Sunday free. Only problem I had was with the recoil starter on the trencher (rope broke and it too about 20 minutes to fix).
Good luck.
/ Trenchers? #12
Here's a thought. I don't have autocad or pictures. I've been thinking of using 3 pt hitch trailer reciever that is readily availble for cheap and make a "plow boom":confused2:
For my "plow boom" would simply be a 2" square tubing that fit the the recieve end, and the other end I would use a scarfier bolted to it.
I hope you can see the picture in MY head:confused2:
Same idea as sub soiler just longer in length away from the tractor so that you can get more travel rise and depth.
If the scarfier isn't deep enough you, you could make something from thick plate steel that would go deeper.
I'm having a hard time explaining my idea. Also I said it was an idea but I never said it was a good one!:laughing:
/ Trenchers? #13
The one disadvantage to dragging your wire through rocky soil, is damage to your wire.
If you can use a subsoiler and put the wire in at the same time you have less of a chance of damaging the wire.
Here is a picture of a unit made by one of the TBN members.
/ Trenchers? #14
Exactly what I was thinking except make the 2x2 tubing a little longer for the extra depth.
/ Trenchers? #15
JJ who's picture is that? I've seen it before. I want to know how muck hp he's using to pull it. Do you think my 2320 can pull it buried at a full 18-20" depth?
/ Trenchers? #16
You might have to loosen the soil with one pass and then lower for the second pass.
/ Trenchers? #17
You might be suprised how cheap you can hire it done, On small runs we can do it cheaper than most home owner can rent, the reason is we can set up 3-5 to do in one day. Other wise look at renting a walkbehind and don't rent the small ones. Get one with steering.
Also get locates it will save you alot of headaches.
/ Trenchers? #18
Brother -
I have been slowly improving our small ranch over the last few years...doing some work as we save up the cash....and have buried 1500 feet of primary power line 5 feet deep and then the same length 2" water main at 4 feet...
The Short Story is: Go Big or Go Home....
Don't succumb to the lure of the lower rental cost of a tool designed to bury irrigation tubing in a suburban lawn or a home-brew or even a purpose-built commercial attachment for your tractor....and for GOODNESS SAKES don't even THINK about a walk-behind unit...that is madness...
You need to bury your water mains deep...don't scrimp...
18" is not a lot of overburden on a 2" water line...the pipe motion / deflection during pressure cycles or ground temperature changes may be enough to dislodge or flex your pipe, allowing enough motion to stress and break the glue joints...pin it down with enough weight...smaller lines of say 3/4" or so might be fine at a shallower depth, but consider that a 2" line at 40psi will exert 250 pounds against a closed valve, elbow or cap. 36" would not be too deep...48" would be better...
I went with a gasketed water pipe for my 2" mains to avoid the issue of glued joints almost entirely....but I had to account for a lot more motion of the pipe in exchange...a little enginerering work...
If you must do this work yourself...it won't easy, but you will save a bundle...
Have your right-of-way well marked with flags, paint, breadcrumbs or whatever...then call "ONE-CALL" or whoever surveys for buried utilities in your area....and let them certify it free of underground utilities....fail to do that and snag somebodies unmarked fiber-optic data line and you will regret it for the rest of your life...
Once you have the "One-Call" certification in hand -
RUN....do not walk....to the nearest sizable town....stop at a decent donut shop along the way and buy the BIG box of assorted sweets...
Find the local equipment rental dealer and schedule delivery of the BIGGEST ride-on trencher they have on the lot for early on the morning you want to do the job....then give the donuts to the crew in the shop and ask them to give you a good lesson on operating the beast....find a machine in the yard you like....one that you can operate confidently and smoothly....specify THAT machine....don't forget to buy a damage waiver....
Well before delivery day, have your pipe glued, pressure tested and laying to one side of the right-of-way...ready to bury...
Make sure you have a good spot to back the delivery truck into...check out EVERY switch and control on the machine....take pictures with your cell phone to show and settle who damaged what....
Get it on....
You will cut more trench faster than you will believe possible....the big machines will chew through hard-pan and roots, dislodge stones and buried trash that will choke a smaller machine....the heavy machine will give you almost perfect control of the depth and allow you to accurately pitch the line if you wish...and leave a level trench bottom covered with fines that will make a perfect bed for your pipe.
If you break the machine....a nice man in a service truck will come and fix it for you...or bring you a new machine....remember and rejoice in the money spent on that damage waiver...
Once the trench is the way you like it, lower your line into the trench and then use the blade on the front of the machine or a box-blade on your tractor to back-fill...
Knock the mud and crud off the machine...park it for the pick-up...have a cold bottle of water handy for the delivery driver...
After you wave goodby to the delivery guy, step back, pull the pin on a cold adult beverage and then admire your work and the roughly $5K - $10K you just saved...
...and next time you are going thru town, drop of a few more donuts off at the rental yard....you may need those folks again...
Be Safe and Good Luck....:thumbsup:
Terry
/ Trenchers? #20
Your not burying water pipe are you? You need to bury that at least 4 feet to be a good way out of the frost line. You may know this but just making sure
KUBOTA L3410 TRACTOR (A60430)
KUBOTA L3410...
16001 (A55853)
16001 (A55853)
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2006 Freightliner M2 106 T/A Dump Truck (A59230)
2006 Freightliner...
