Calibrating Spike Aerator Drop Spreader Combo
   / Calibrating Spike Aerator Drop Spreader Combo #1
mbrun
Member
John Deere 2010 x500
I own one the Brinly combo units. Calibrating using the garage floor method is not possible because of the spikes. Calibrating using the drop pan method using rain gutter is not possible, again because of the spikes. And calibrating by repeated dropping of material on a metered distance course is a waste of material ( or potentially harmful to the lawn), time consuming and difficult.
So my questions to those of you that do calibrate your aerator spreaders:
What method do you use?
Do you calibrate for each type of material before you apply?
If you use a drop pan/tray what did you make it from?
I am contemplating a jig to hold the spreader off the ground, putting a drop pan beneath the elevated unit, then using a drill to rotate the spike axle a number of times to represent a given travel distance.
What say you?
   / Calibrating Spike Aerator Drop Spreader Combo #2
Big piece of cardboard to run it over?
The spikes would puncture through the cardboard. Perhaps someone has found a way to make a catch tray for this one?
   / Calibrating Spike Aerator Drop Spreader Combo #4
Right, that's the point. Lay it down on the concrete and run it over it your measured distance using your garage floor method.
Ok, now I see where your going. Use the cardboard to protect the tines. Nice thought!
Hmmmmm.
FAKE (A52472)
FAKE (A52472)
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
