Calibrating Spike Aerator Drop Spreader Combo
   / Calibrating Spike Aerator Drop Spreader Combo #1
mbrun
Member
John Deere 2010 x500
I own one the Brinly combo units. Calibrating using the garage floor method is not possible because of the spikes. Calibrating using the drop pan method using rain gutter is not possible, again because of the spikes. And calibrating by repeated dropping of material on a metered distance course is a waste of material ( or potentially harmful to the lawn), time consuming and difficult.
So my questions to those of you that do calibrate your aerator spreaders:
What method do you use?
Do you calibrate for each type of material before you apply?
If you use a drop pan/tray what did you make it from?
I am contemplating a jig to hold the spreader off the ground, putting a drop pan beneath the elevated unit, then using a drill to rotate the spike axle a number of times to represent a given travel distance.
What say you?
   / Calibrating Spike Aerator Drop Spreader Combo #2
Big piece of cardboard to run it over?
The spikes would puncture through the cardboard. Perhaps someone has found a way to make a catch tray for this one?
   / Calibrating Spike Aerator Drop Spreader Combo #4
Right, that's the point. Lay it down on the concrete and run it over it your measured distance using your garage floor method.
Ok, now I see where your going. Use the cardboard to protect the tines. Nice thought!
Hmmmmm.
2022 Toro 21in Hydraulic Walk-Behind Turf Aerator (A52377)
2022 Toro 21in...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
SCAN FOR HAULING AND FINANCING INFORMATION (A54756)
SCAN FOR HAULING...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
