Weight Distributing Hitch On Dump or Equipment Trailer?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #42
Now I'm debating putting a WD hitch on my tilt trailer. I suppose I'll have to unhook the torsion bars each time I load or unload.
I've been wondering the same thing. With a dump trailer the loads tend to vary greatly between being loaded and empty. Torsion bars on when loaded, off when empty?
   / Weight Distributing Hitch On Dump or Equipment Trailer? #43
Or just loosen the chains a few links when empty.
I've used my trailer a little since that last post with and without a WD hitch. I'm finding that when hauling my little tractor it's not even worth the hassle of the torsion bars. When I load the trailer to capacity with hay however, it makes a big difference. I'm glad I considered WD hitch brackets when I modified my tongue. It's a very convenient option to have.
   / Weight Distributing Hitch On Dump or Equipment Trailer? #44
I'm a huge believer in Weight Distributing hitches. I pulled a 30 foot camper with my 1/2 ton truck for a few years. I couldn't have done it without the WD Hitch.
Yes you will have to unload the torsion bars before tilting a tilt bed trailer. I forgot and made that mistake one time. The back of my trailer A frame goes up when the bed is tilting and puts a lot of extra force on the bars. If the frame stayed level and only the bed went up it wouldn't be a problem. My tilt bed is only a 7K trailer so I don't use a WD hitch on it any more.
I also use the WD hitch towing a 30' camper. For my camper I use 1000 lb. bars with the WD hitch. I also have a 2nd WD hitch with 1200 lb. bars but rarely use it. I know if I sold that hitch I'd need it a week later.
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
