Rustyiron
Super Member
As mentioned, cost/sf is allways cheaper "going up" but in Fla. you might have some extra cost on the 2nd floor if there are special (structural) huricane requirements on the bldg. code. Will a 2nd fl get you a better view?
Goose your logic is backwards. 2 story's have much less exterior wall surface for the same SF as a 1-story. If you want your ducts accessible, you can use drop ceilings or removable panel ceilings in key areas. No law says you need drywall there...
