Distilled Water
   / Distilled Water #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
Can it go bad? I have half a jug of it that has been on the shelf for several years that I only use for topping off batteries.
I have a feeling this is one of those questions that the answer is --- if you have to ask, you probably already know the answer.
   / Distilled Water #2
Unless some organism got in it and grew, then it should be just fine. If it has been sealed setting on the shelf I don't see how anything could get in. The water in itself is not going to go bad.
   / Distilled Water #3
I keep distilled water for batteries and for various family medical devices. I have kept some for a year or more without a problem. The medical folks say that, since distilled water has nothing in it, it will keep indefinitely. Since is is in a plastic bottle, however, eventually there may be a tiny bit of plastic substances that move into the water, but so small an amount it probably cannot be detected.
   / Distilled Water #4
The plastic getting into the water is definitely detectable but not harmful to batteries at those low concentrations. Like everyone said, no worries mate. If you don't see any discoloration to indicate biologic growth due to inadvertent contamination then the water is as good now as when purchased. Also it should pass the smell test. It will probably just smell like a plastic container. If there is some other smell it might have become contaminated.
Patrick
   / Distilled Water #5
At 88 cents per gallon. I would just buy a new gallon
   / Distilled Water
I gave it the look and sniff test then topped off the battery. Thanks for the advise! I figured if I just poured it in without asking, with my luck, the garage would burn down.
   / Distilled Water #7
A look and sniff test! Oh pshaw, pshaw! Just have a good swig and a gargle! :D :D :D
   / Distilled Water #8
It will be fine. Good to hear you have good sense and use distiller water in batteries and cooling systems. Those folk who use water from the tap have no clue.
   / Distilled Water #9
You better watch out for what they are passing for distilled water. There is a company out here that is doing reverse osmosis, micro filtered and UV treated water as distilled. The people in the store said it was equal but it is not, close but not the same. As for shelf life old stuff is fine for batteries and radiators but I would get fresh for medical uses.
David Kb7uns
   / Distilled Water #10
The old fashioned rainwater caught in a clean glass container does the job for me , had some on the shelf for nearly 5 years good as the day it fell.
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED TRAILER (A54607)
2025 GREAT DANE...
2014 Electric Cart (A53424)
2014 Electric Cart...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
